Posts: 3.5K,
Visits: 472.0K
I found a clutch fork among my extra parts. Not sure what it came off of but pretty sure it a Y Block fork. Could be either a sedan or a TBird - Are they the same or different? Overall length is 11 inches. The distance between the adjusting rod hole and the other end is 9 1/2. The distance between the "prongs" is 2 1/2 c/c. Distance between the fulcrum and the prongs is 4 1/2. Any one have a clue to what it goes for. Thanks
Visits: 132.5K
T Bird and passanger should be the same. Fe should allso work. When I put the large input toploader in my T Bird one option was to use a 428 CJ fork to clear the larger front bearing retainer on the toploader. I split and spread mine instead. Much cheaper.
