Timing covers
Posted By monarch 7 Years Ago
monarch
Hitting on all eight cylinders (24 reputation)Hitting on all eight cylinders (24 reputation)Hitting on all eight cylinders (24 reputation)Hitting on all eight cylinders (24 reputation)Hitting on all eight cylinders (24 reputation)Hitting on all eight cylinders (24 reputation)Hitting on all eight cylinders (24 reputation)Hitting on all eight cylinders (24 reputation)Hitting on all eight cylinders (24 reputation)
Posts: 13, Visits: 1.2K
what is the difference between a car and a truck timing cover. I have two covers that both have threaded holes on the top of the cover for properly a bolt on acc. ?? If there is a difference is there a difference in the harmonic balancer. Thanks
Last Active: 8 minutes ago
Posts: 3.7K, Visits: 323.0K
On truck covers for use with a front mount, the lower 4 bolt bosses are tall enough that about a 3" bolt is used to bolt the ;mount and cover.  Passenger covers have "ears" cast on them and use about 1" long bolts.
monarch
Thank you
pintoplumber
Last Active: 7 hours ago
Posts: 1.0K, Visits: 164.2K
Some of the early truck timing covers had a high mount water pump
 driven off a separate belt. I don't know when the high mounts were discontinued.
Or was it a high mount fan? I forget.
Rono
Posts: 1.3K, Visits: 80.0K
I have a truck timing cover with a square boss on top that has two, 5/16" threaded holes for mounting something. I thought this might have been for some commercial use, but I'm not sure what.
