Visits: 252
I'm sure that this has been answered before, but can you run the later 57+ distributor on a 6v positive ground system? I got a B manifold and distributor and carb for a deal. Wondered if it'd be ok to use on my 55 that's still 6v? I'm thinking about doing a set of Spotlite's headers on it when I get the exhaust redone so figured that 57+ stuff would help make a little more power on top of that.
Blood stains. Speed kills. Fast cars. Cheap thrills.
Last Active: 5 hours ago
Visits: 323.2K
Sure you can run the distributor on six volts. No problem.
Visits: 252
Awesome. I just was unsure if the 6v coil would be hot enough for it. thanks bud
Visits: 102.7K
I believe the 6 volt outfits don't use the ballast resistor........true?
Steve Metzger Tucson, Arizona
Visits: 32.6K
GREENBIRD56 (3/14/2018)
I believe the 6 volt outfits don't use the ballast resistor........true? No Ballast required.
