Main jet and rod for Carter 600cfm
Posted By Kenneth1986 8 Years Ago
Kenneth1986
Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)
Posts: 2, Visits: 11
What size of main jet and rod would i put in my carter 600cfm that comes on a rebuilded 292? So it would run nice
Posts: 1.9K, Visits: 194.9K
There’s really no answer for your question based on what you told us. First figure out which Edelbrock carb you’ve got. Typically a 1405 or 1406. They set up differently. Download the manual for the right carb, and go to the jetting chart in the back. It’s very detailed and I needed to study it for a while before I got my head around it. That gives you a start on the main jets, rods, and springs.
You probably should start with the the initial factory setting. Those different models that “look” the same often came with different combinations. Even if the carb is new, they’ve been know to mis jetted from the factory. So do that homework first.
Ambient air temperature, altitude, engine mods, cam, compression ratio are all going to be part of the equation. Engines that look identical on paper may end up with slightly different tuning.
Kenneth1986
Thanks Miker
The carburator is a 1406. I downloaded the manual and im no going to reset the factory setting and start there as you said. Its a old carburator that i cleaned up.
