Carb spacer for PCV hookup
Posted By PF Arcand 7 Years Ago
Posts: 1.8K, Visits: 306.3K
The above install photo is not CASCO, but will give you an idea of final appearance.
It is also a 2V install using the OEM later truck PCV adaptor at the valley pan (also later production).
The idea is to have the PCV fumes go directly into the intake carb plenum for equal distribution of fumes to all cylinders and not loading up of certain cylinders by themselves, leading to plug fouling/detonation.
See how the installer has placed a phenolic spacer above the aluminum spacer for heat transfer control?
56_Fairlane
Last Active: 10 Months Ago
Posts: 575, Visits: 14.6K
I'm concerned about the heat transfer too. The PCV spacer is about thickness as my phenolic spacer I used before I started this conversion so I didn't change my studs. Maybe I should get longer studs to add the phenolic spacer?
I've got enough room under the hood on my '56.
~DJ~ AKA "Bleach"
56_Fairlane (3/2/2018)
You have the CASCO spacer now?
You have a '56 with a '57 4V intake? What carb are you using?
The trouble with hi-stacking carb spacers is at some point it has an effect(s) on the flow characteristics of the mixture flow. You can actually chance HP/torque by varying height.
I wish I had come across this earlier as there is a phenolic spacer available 1/4" thick with the vacuum provision.
56_Fairlane
Yes I have the Casco spacer now but I haven't tried running the engine with it yet. I don't think it would be too tall to affect anything but heat transfer if I added the '57 phenolic spacer. It would probably only be about an inch thick if I added it. I realized I'd need another carb gasket if I did. I still have a few more things to do before I can start it up.
I'm running an Autolite 4100.
We've talked about my carb at the Barn or the HAMB before. Wink
~DJ~ AKA "Bleach"
57 R jim; Appreciate your suggestion, but as pointed out, the non flat underside of the Ford spacer likely won't match up with the raised edge B intake.. Kultulz; thanks for the excellent photo of an installation. I have a later valley pan to allow the PCV connection at the rear. However, I'm not going with an actual Casco setup due to the delivered cost here. Still looking into an alternative. The other concern that needs clarification for me is, the connection thru to the rear venturies of the carb?. Since the rear plates are closed normally, will the system work properly ?
If the spacer is installed so that the port is on the secondary side, it will still be exposed to manifold vacuum so it will probably be ok in that respect.
Posts: 3.6K, Visits: 497.8K
I get 5/16 NC/NF studs at my local Sears Hardware store.
I’ll suggest putting the PCV hookup in the rear of the carb spacer rather than at the front.  The vacuum signal is the same on both ends of the spacer and with the hookup at the back, there is more room under most carburetors at the secondary side.  The PCV hose will also be better hidden and out of the way.  The other option is to use the 3/8” nipple on the carb base if it has one.  That particular nipple is suitable either for a PCV hookup or power brakes.  It’s always a good idea to keep the power brakes and the PCV on separate connections if you have both.
VERY GOOD INFO POSTED HERE-
PF Arcand (2/26/2018)
Scott: If you are presumably using a ECZ-B manifold & still dealing with the carb situation, before you spend more money on it..take the carb off & make sure you have a proper seal to the intake. Due to the raised design of the intake flange, larger 4 Bbl carb gaskets such as a #55 will barely seal if at all, causing a vacuum leak..
56 Fairlane-
As long as yours is not assembled yet, can you give the ID of the carb mounting throttle bores and the 4100 throttle bores, as well as the CASCO spacer?
I am trying to cipher on something... Wink
http://forums.y-blocksforever.com/uploads/images/57c1f92e-4801-41be-ba2e-1470.jpg
.http://forums.y-blocksforever.com/uploads/images/a83b9cc4-6aef-4f38-9c23-8a90.jpg
OH!
On the actual valve. I would try to find NOS as it is machined and can be serviced regularly as opposed to a cheap aftermarket which may not be calibrated correctly.
56_Fairlane
Kultulz, sorry I finished putting it together yesterday. All the throttle bores were about the same size, including the carb. As you might recall from my other posts at the Barn, I'm using a '57 model 4100 Autolite with 1.08 venturis if that helps.
Hmm, which NOS PCV valve are you suggesting? I've read people have tried using different ones ranging from one from a 2.3L to the 460?
~DJ~ AKA "Bleach"
