Rocker Arm/Pushrod Geometry
Posted By paul2748 8 Years Ago
Posts: 3.7K, Visits: 498.2K
How does this  look for the proper geometry - new cam and making sure its correct.  There is zero lash in pictures - longer pushrod?http://forums.y-blocksforever.com/uploads/images/221f1e5f-fb78-481d-98ee-2488.jpghttp://forums.y-blocksforever.com/uploads/images/befb347f-f591-45dc-85c4-f31d.jpg
skipLYB
Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)
Posts: 5, Visits: 18
What's the lash from cam manufacturer? You really have to set the lash before you can judge the valve geometry. Then rotate the engine through each cylinder's 4 stroke cycles and watch rocker, pushrod, and valve movement with no deflection where the pushrod cup and rocker ball move together (the pressure point should stay to the center of both parts during the opening, closing, and peak lift) and the same for rocker tip & valve stem.
Doug T
Posts: 563, Visits: 2.6K
You might consider taking the oil deflector plates out from under the shaft stands. Of course if it is entirely stock 55 or 56 you are going for, than longer push rods are the only option. But it would probably run OK the way it is for a long time. The change in geometry at the valve is not that extreme IMHO
Doug T
An easy way to eyeball it and get an idea is to observe the angle of the screw relative to the pushrod.  If geometry is close to optimum, the angle at 0 lift should be exactly the same but opposite at full lift.
Another way, if you have a dial indicator, position the rocker arm so the valve is at half lift.  At this point, the screw and pushrod should be directly in line.
The best way is to blue the tip of the valves, turn the engine a few times and then observe the pattern on the tip of the valve.  Add shims until that pattern is the narrowest.  This is best to do with an adjustable pushrod so that the adjuster screw remains in the same position, and therefore the rocker assembly has the same ratio for every test.  If you simply add shims and then adjust the screw, you change the ratio each time.  You will probably run out of adjustment, at some point as well.  Once the shim thickness is known, make spacer to match and order pushrods of the length determined by the adjustable pushrod.
Paul.  GooD thoughts from other Forum members.
Consider looking at some of the diagrams and related information in the article Ted wrote regarding rocker arm geometry.  Click the linkbelow to go to Ted's web site . . .
http://www.eatonbalancing.com/2007/12/10/rocker-arm-geometry/
Hope this helps!   Smile
Charlie
