'57 F100............progress
Posted By jecklhyde 7 Years Ago
Rated 4 stars based on 1 vote.
jecklhyde
Turbocharged (53 reputation)Turbocharged (53 reputation)Turbocharged (53 reputation)Turbocharged (53 reputation)Turbocharged (53 reputation)Turbocharged (53 reputation)Turbocharged (53 reputation)Turbocharged (53 reputation)Turbocharged (53 reputation)
Posts: 23, Visits: 18.9K
http://forums.y-blocksforever.com/uploads/images/7bfcd189-25ae-4bf9-a43a-955c.jpg
I'll post
http://forums.y-blocksforever.com/uploads/images/f8c8be12-bf95-49ea-b04b-b470.jpg
1960fordf350
Supercharged (248 reputation)Supercharged (248 reputation)Supercharged (248 reputation)Supercharged (248 reputation)Supercharged (248 reputation)Supercharged (248 reputation)Supercharged (248 reputation)Supercharged (248 reputation)Supercharged (248 reputation)
Posts: 110, Visits: 2.9K
Nice truck.    Did you absolutely have to have the 3/4 shaft?    I know O'Reilly's has new lifetime water pump for  $90.  Prices have gone up,  I bought a new pump in 2010 and only paid $36 for it.
Did that 4 speed come in that truck?   I don't see a master cylinder for the clutch.   I didn't know which year started hydraulic  slave for the clutch.
http://forums.y-blocksforever.com/uploads/images/2e6780b3-6e07-4836-8bf9-c3da.jpg
1960fordf350
We're all bull headed in one way or another.   I love the stock look of my truck, so I won't change out the 6 lug rear axle for an 8 lug.   Mine has the T98 also,  a lot of tranny for a half ton.
Did you try looking for a Borg Warner with the overdrive?   That would hold up and scoot you down the road.
1960fordf350
No,  T98 was never an overdrive.   I was talking about a T85 R11 combo tranny.   Those trannys were used in all kinds of cars,  Fords,  Mercs, Lincolns,  and Stupidbakers!
I just acquired one that was behind a 312 I just bought.   Its gonna get sold here in a while.   My truck has an  auxiliary transmission with overdrive.   5831 Spicer 3 speed.  So I've got a
4 + 3  in my truck.
FORD DEARBORN
Posts: 779, Visits: 113.4K
Greetings: Checked my 57 car shop manual and 64 F100 manual, both list the rocker shaft to cylinder head torque as:  12-15 foot-lbs..   Hope this helps, JEFF...........    That '57 truck is going to be mighty fine.
Last Active: 4 hours ago
Posts: 6.1K, Visits: 442.6K
Yep, 12-15.  20 is pretty high.  That is more like the lower end of a grade 8 spec.
Jecklehyde.  The y-block Ford torque table offered below is from Tim McMaster's web site.
Click the link below to take you there.
http://www.yblockguy.com/techtips/yblocktorquetable.html
Hope this helps.  Smile
FORD DEARBORN
Great progress, looking mighty good and also like that tag..........................
1960fordf350
That's cool.  I've actually run the strap under the intake manifold and used it to lift an engine in and out!
1960fordf350
Nervy?   I used a ratchet strap,  not a lifting strap!   Lifted a 332 Lincoln Y that way too.   Believe me,  that's a heavy beast.  Especially when the bell and flywheel are still on the back.
