Wipers of intake
Posted By Melly 7 Years Ago
Posts: 3.6K, Visits: 497.7K
As far as a an electric fuel pump  in conjunction with a mechanical, makes sure the electric is a flow through so there is no problem using the mechanical only.
You are going to try to use a wiper motor that is of dubious value.  If you have the cash, I would convert to an electrical wiper motor, assuming you are 12 volt
2721955meteor
Posts: 927, Visits: 190.0K
YEs i use 1 to prime the carb after long shut downs,put it close to the tank,it works as a check valve when not turned on. i use a starter button so it is not on only for emergency. RE the wiper issue install a vacuum tank (small 1 with proper check valve  that way even on a long hill should keep wiper going
Melly
Posts: 201, Visits: 48.3K
Thanks for info. Could you put stock fuel pump in along with the electric pump? Maybe leaveing the electric pump off? If so would you split the gas line?
Posts: 1.9K, Visits: 194.9K
Assuming the vacuum motor is good, they will work fine off manifold vacuum at idle or cruise. Uphill, they stop till you let off. The search function here will bring up some post about rehabbing the vacuum motors with oil or ATF or whatever. Back in the day my wipers didn’t work that well even with the right fuel pump.
Melly
Have 272 2 barrel three on tree with od. Was wondering if I was to plum wipers of intake what issues would I have? presently has electric fuel pump wipers not hook up. Would like to at least have something til I could go with electric wipers.
