Visits: 48.3K
I have a 3 spd on the tree with OD. Considering changing to AT as i have some issues with knee. So would like to know thoughts of the way to go forward with this? Don't want to break bank doing it. with
Visits: 13.4K
I think the easiest and cheapest, would be a 1958 to 1962 Cruise O Matic from a 292 car or from a truck if it's going into a truck. Car and truck transmissions are hard to interchange. you will need the steering column, pedal set, throttle linkage, cooling lines and all rods, also make sure that you have a cooler in the radiator.
Posts: 1.8K,
Visits: 194.1K
Welcome to the site, lots of great folks here.
Like Cliff said, we need a little more info about your ride. You’re talking about going from 3 speed with o/d to a straight 3 speed auto, and that willprobably require a rear gear change. Or a 4 speed auto, like an AOD.
So fill us in a bit, and away you’ll go. Whatever you want some one here has done it.
Visits: 48.3K
Don't really know what I want. Was looking for one that had A/T already in it. But this was such a great car I could not pass it up. So looking for options that would work without breaking bank but would want to do it right. I have a stock 272, 2 barrel carb, dual exhaust , 3 spd. with OD. Seem to run great but only had a short time to drive it before the MN. winter set in.Plan to drive to shows and roll ins and just enjoy a blast from my past.
Visits: 190.0K
in your case i would look for a 55 56 air cooled torqe fordomatic. be sure to get the throttle linkage drive shaft etc. best bet is find a junked car if you are converting to a car. if you find one you also need the reg axel or the diff asm as od manual to low a ratio. it is a lot of work.maney will talk down the older ford autos,but for a 272 you will not have any issues, and they are a 3speed,and will start in 1 if set up correctly. if you get a parts car you will have all the small hard to find parts.. be aware truck trans are quit different
Visits: 29.3K
Melt, I have a air cooled fordo I just pulled out of my 55CV. Worked well when pulled maybe 3 months ago. Think I can still find all the linkage and the complete peddle assembly for the auto. Even have the selector arm and shaft for the column. I live in woodland ca. I don't ship because the stuff is not for sale. If you or a rep wants to come get it I'll be be happy to give it all to you. I have no use nor a place to store it. It will soon all go to big John up in Williams and perhaps he can find a home for it. PM or reply here for more info if needed.
Rowen 55CV Woodland, Ca
Visits: 29.3K
Sorry "Melly", spell check.....
Visits: 48.3K
I have some interest in your parts could you email me sadrevlow@gmail.com
Visits: 48.3K
my
Visits: 1.7K
its funny maybe how weve come full circle.when i was young everybody wanted a standard.a lot changed them over.now we want automatics.full circle.
