Follow John's instructions. You will need to drain a precise amount of coolant and then top it off with straight antifreeze, not 50/50.
Since the engine and radiator are linked together with hoses, which contains more coolant is inconsequential. Draining via the radiator will drain some of the engine and draining the engine will drain some of the radiator.
