1946international
Visits: 21.4K
Is there a difference in flywheels that came from a truck motor? Maybe even a larger truck motor? I have a '59 292 motor and I'm having a hard time finding a ring gear for it, I bought one off the internet and it would not expand enough to go over the flywheel, I found another one from NAPA and they list the I.D. of the gear. It looks like that gear will have to expand .15" to fit over the flywheel, too much? I think it is. I sent the other gear back and did not measure it but know it was too small, I heated it with torch and stuck 'wheel in freezer. The correct gear will have 146 teeth and the flywheel in question uses a 11" clutch.
jecklhyde
Visits: 18.9K
I'll throw in my two cents on this one, My general "rule of thumb" for "press fit" is.001 per inch of diameter, so, .015 would be acceptable for a 15" ring gear. Be careful with the torch; 500 degrees is all it takes to remove the hardness from the heat treated ring gear. Maybe....cool the flywheel as you said and oven the ring 200-300 degrees....should drop on.
aussiebill
Posts: 1.8K,
Visits: 11.4K
Y block flywheels are same except in hole locations for 11" clutches, but what i have found were some ring gears were too small in the internal diameter to expand far enough to fit, these i,m guessing were imports and wrong.
Rono
Posts: 1.3K,
Visits: 80.0K
If the teeth on the ring gear are only worn on one side, you can just flip it over. Save you the trouble of getting another one.
Ron Lane, Meridian, ID
57RancheroJim
Visits: 112.0K
Rono (12/23/2017)
If the teeth on the ring gear are only worn on one side, you can just flip it over. Save you the trouble of getting another one. I don't think you are suppose to do that. The flywheel and ring gear surface aren't a perfect 90 degree edge, thats why the ring gear has a small beveled/chamfer on one inside edge. That side goes against the fly wheel. I bought a Pioneer from Rock Auto and a little heat from a torch, light tapping with a hammer and it went right on..
56ranchwgn
Visits: 3.2K
I had this problem a few years back, I think most of the major suppliers were getting their ring gears from the same source they were made in mexico and they were slightly undersized no amount of heat would make them fit. they may have been sized for a small block Ford. I finally found an NOS one from Joblot in New York but I'm not sure if they are still in business.
314
Visits: 1.7K
you can flip over the ring gear people have been doing that forever.
OlWeldinrig
Visits: 2.5K
Just flipped my ring gear this summer.Works fine.
Posts: 3.3K,
Visits: 238.8K
Re Joblot Automotive. It's my understanding they have closed up in the last year or so..Unfortunately, I don't have any info as to where their stock may have gone.. Anybody know?..
RB
Visits: 16.7K
