Visits: 413
I have a 3 speed transmission with the R10 Borg Warner overdrive. The transmission is a T86AA-1. From what I have read this was primarily put in Jeeps. Will this transmission work with a 292? The number for the bellhousing that I need to use would be helpful also if anyone knows it. Thanks for any info you can provide.
Visits: 8.3K
All y-block standard shift bell housing are the same, measure the bolt spacing for the transmission bolts on the bell housing and the trans you have..
Visits: 14.3K
The T86 was used in Fords also so it shouldn't be to difficult to put in. It does matter if its a car or truck transmission though. I have a T86 OD out of a 56 car if you need some measurements to compare.
Durham Missouri
Visits: 22.0K
"Will this transmission work with a 292?"
It will work with a stock or nearly stock 292 but that's about the limit. If you're in the habit of re-living a misspent youth by lighting up the tires pulling out of the Dairy Queen it won't last long.
Visits: 609
Also there are different tail shaft lengths on the overdrives... Does anyone have a rundown on the lengths,btw? since i need one for a spare
