9 inch
Posted By saladbar 8 Years Ago
saladbar
Posts: 4, Visits: 34
what 9 in rear end fits 1960 f 100 truck thanks John
Last Active: 1 hour ago
Do you need it to be a bolt in or can you relocate brackets as necessary?
saladbar
thanks can move mounts John
Small block
Posts: 90, Visits: 2.5K
according to the information I have  the Ford F100 was the same width from 1957 to 1972  so any rear diff from 1967 to 72 would be the 9 " that would be a good fit! The specs say it is 61.25 inches to the  out side.
mongo
Supercharged (385 reputation)Supercharged (385 reputation)Supercharged (385 reputation)Supercharged (385 reputation)Supercharged (385 reputation)Supercharged (385 reputation)Supercharged (385 reputation)Supercharged (385 reputation)Supercharged (385 reputation)
Last Active: 7 Months Ago
Posts: 224, Visits: 556
I know I have some housings for that app , where are you located ?
Po ol Davie
Sparta , Tn.
stuey
Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)Supercharged (857 reputation)
Posts: 443, Visits: 3.8K
this might be of use    http://www.enjenjo.com/9inch.html
stuey
saladbar
Thanks all located in Lincoln CA
