Visits: 67
I have a 56 merc montclair with a burned out signal light switch. My book indicates the part number for the switch is FDT 14486-A. Lincoln Mercury Old Parts Store has a NOS switch for $175.00. Macs list a 56 ford switch B8A-13341-A that says Ford only. I contacted them. They indicated it would probably work. Has anyone used this switch on a 56 Mercury? Part number FEK-14486-A indicates it will fit a 57 Ford and looks exactly like the 56 Ford one and my 56 Mercury including the same color wires. Does anyone know what the difference FEK an FDT. Any help would be appreciated. Thanks Larry
Larry
Visits: 32.4K
quote] lalkie (10/16/2017)
I have a 56 merc montclair with a burned out signal light switch. My book indicates the part number for the switch is FDT 14486-A. Lincoln Mercury Old Parts Store has a NOS switch for $175.00. Macs list a 56 ford switch B8A-13341-A that says Ford only. I contacted them. They indicated it would probably work. Has anyone used this switch on a 56 Mercury? Part number FEK-14486-A indicates it will fit a 57 Ford and looks exactly like the 56 Ford one and my 56 Mercury including the same color wires. Does anyone know what the difference FEK an FDT. Any help would be appreciated. Thanks Larry [/quote] I have a 56 Mercury Catalog dated 1955, The Part # in there is FDL-14486-A which may be changed to FDT-14486-A in the later Catalogs. Dennis Carpenter has a lot of NOS Parts not listed on His regular Website. You might try a Phone Call to them and see if they have either of those Part #'s in their NOS Stash. You might also try Green Auto Sales who are Obsolete Ford Parts Business. They show out of Stock on both those #'s but doesn't mean its up to Date. They may know where they can get One or if something else will work.
Visits: 426
I used the one from Macs, on my 56 merc had to modify the side, ground off the side to make fit, works great
Visits: 67
Thanks for the help. I probably go with the one from mac's. It may mount differently but should work with the wiring. I will also check other options. Thanks again. Larry
Larry
Visits: 426
Mounting holes are the same, just remove the material on the side
Visits: 67
John is correct. I removed the material on the side and it works well. Thanks Larry
Larry
Visits: 426
I am finally putting my turn signal spring on cant figure how the spring goes, would someone put a picture how the spring mounts on 56 merc
