autolite 46 going back in. My build doesnt like the 45s
Posted By ianmatt 9 Years Ago
ianmatt
Question Posted 9 Years Ago
Supercharged (254 reputation)Supercharged (254 reputation)Supercharged (254 reputation)Supercharged (254 reputation)Supercharged (254 reputation)Supercharged (254 reputation)Supercharged (254 reputation)Supercharged (254 reputation)Supercharged (254 reputation)
Posts: 96, Visits: 443
Anyone have any input here or have this same experience. Since my build 292, bored .030, pertronix 2, header, mumert intake, summit 600 carb, original 4 speed T98...
My engine builder installed autolite 46, after about 6 months i put in 45s as it seemed to be the preference for some longer highway driving. Which I do from time to time but not often. Somehow my engine seems to lean out and stop pulling around 2800 rpm. I have checked timing, trid different carbs. Something is up and I am not sure what. I am thinking I might put the 46s back in. what is the best gap for the 46s? Thanks folks.
Leaning out is not plugs.  Since you have tried two carbs, and assuming they were reasonably well tuned, you probably have an ignition or fuel supply problem.  If you did not spend time tuning, then you need to.
I think the 45s probably are not necessary for your build since it sounds pretty well stock with a few bolt-ons.  Gap will be the same, about .032 for stock ignition, possibly wider for electronic ignition.
ianmatt
.\Thanks Charlie, so do you think then that the 46es are better for what i have? I do have plenty of fuel pressure.
ianmatt
also it would backfire through the exhaust when I step on it. i may have a timing issue
I think the 46's are probably fine but it does sound like you have a tuning problem.
Posts: 3.8K, Visits: 33.4K
ianmatt (10/2/2017)
You might check and see what your total available Advance is. Initial + Vacuum+ Centrifugal. You should be aiming for around 44 total. What do the Plug Insulators look like color wise?.
Small block
Posts: 90, Visits: 2.5K
What  a bout a  vapor lock That would cause  the problem your talking about, and  highway driving  is prime time for it to happen!
Check your balancer if its original for possible slippage, not uncommon. And your distributor isn't pre 1957 by chance?.. If so, it won't work properly with that later Summit  carb..
2721955meteor
Posts: 927, Visits: 190.0K
57ford 292 with holley 4v and ford dura spark ign, similar issues,turned out to be to lean,put larger  jets in primaries. problem cured. prev replaced durs module and coll,no cure ,richer primaries cured the issue.
