1954 Mercury Monterrey
Posted By mars54 9 Years Ago
mars54
Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)
Posts: 41, Visits: 1.2K
Hi, I need a turn signal switch and the lens for my dash. I was told by a reliable source that the Ford switch is different from the Mercury. Looking for sources to purchase these items any suggestions is appreciated.Thanks
. http://forums.y-blocksforever.com/uploads/images/8be26102-fbe7-423b-8023-1ce3.jpgMario
That could be a toughy..Suggest you also repost as a wanted in the "classifieds" here
mrmike
Supercharged (211 reputation)Supercharged (211 reputation)Supercharged (211 reputation)Supercharged (211 reputation)Supercharged (211 reputation)Supercharged (211 reputation)Supercharged (211 reputation)Supercharged (211 reputation)Supercharged (211 reputation)
Posts: 67, Visits: 2.5K
Hi, I have quite a few 54 merc parts, but not the turn signal switch.    I don't know what you mean on the dash lens, because the turn signal indicator is built in to the cluster assembly.  If it doesn't work, it is either a bulb problem or it is not getting the power signal.  Hope this helps.   Mike
Dobie
Posts: 476, Visits: 22.0K
You might contact these folks: http://lincolnoldparts.com/ . Don't let the name put you off, they also have Merc parts.
Last Active: 25 minutes ago
Posts: 3.7K, Visits: 498.3K
.Google Mercury Clubs or Mercury parts  and see what comes up
mrmike
Does either signal light work?    How was the switch checked ?   I am wondering if you had changed out your flasher, which would be an easy step. it is up under the dash by the fuse panel, which is a pain to get to.  I installed a new "modern" fuse panel just above the kick panel on the drivers side. One of the best things I did.
    Also , if you or anyone has been up under the dash , doing some work, it is easy for to move around wires & the bulb  socket for the signal light to pop out. Then you would not see the light flashing.......  hope this helps.   I have some gauge cluster parts..........  Mike
mars54
Hi Mike,
I guess I need to clarify, rear right brake light doesn't work. All bulbs were checked all other including dash indicators turn on/off when the turn signals are engaged. I was told this is an indication of the turn signal not working. As for the lens its the class for the dash in the photo there's a crack in the speedo area I was looking for replacement lens for the dash cluster. Gages have recently been worked on and speedo calibrated. Thanks for all the responses I will try the recommendations.Mario
mrmike
Hi Mario,  I have a dash lens. PM me about it.   The instrument cluster will have to be all unhooked, taken out & taken apart to replace the lens. I also noticed your gauge needles are white because the red faded off them thru the years.  I repainted mine very CAREFULLY !!   You have to put something under them , & the right thickness so they don't move to paint them...........I mentioned this in case you would consider it ,when you have it all apart............    Mike
mars54
Hi Mike, I had the gages converted to 12V and they painted the needles while they were there.I'm interested in the lens. I will attempt the PM. Thanks
Lanny White
Posts: 80, Visits: 33.0K
Mars54, I too had trouble with my right rear turn/stop light.  All indications were a bad ground as the lamp would glow but not brightly and other lamps in the turn circuit acted inappropriately.  I finally found crossed wires in the front turn signal junction block (right front corner at the cross-over wire loom) where left and right were plugged into the same connection.  I had a new wiring harness and was able to trouble-shoot with wire color code.  I simply pulled the incorrectly placed wire and moved it to the correct hole in the j-block.   Maybe this will help.
