Visits: 426
I used a restricted gasket
Visits: 14.3K
Do you gaskets block off the crossover port or are they restricted?
Durham Missouri
Visits: 81.0K
Thanks, I did use grease on the head side and small amount of black silicon adhesive on the intake. I figure when I can afford an Alloy Intake it will remove easily.
Visits: 426
I just replaced mine, I think they will go one way metal up, no gasket cement needed, john
Visits: 81.0K
I have the gaskets with the restricter block off for the heat. Does this face toward the intake or toward the head
Can I just use grease to keep the gaskets in place or do I need gasket sealer/silicon
Thanks Richard
