Radiator
Posted By ronsplace 8 Years Ago
ronsplace
Supercharged (350 reputation)Supercharged (350 reputation)Supercharged (350 reputation)Supercharged (350 reputation)Supercharged (350 reputation)Supercharged (350 reputation)Supercharged (350 reputation)Supercharged (350 reputation)Supercharged (350 reputation)
Posts: 157, Visits: 630
Has anyone located a vendor who produces well-made, bolt-in, two-row aluminum radiators for '55 and '56 Fairlanes with Y block and auto trans?  I found one at Griffin, but they want more than $1k plus shipping.  Honest!  Can't believe they have the nerve to ask that kind of money.  If anyone has located a source, please pass it on.  Even if it's not an exact bolt-in and requires some fabrication, that would work.  Thanks, Ron
Posts: 1.9K, Visits: 194.9K
There's been post either here or the Ford Barn about an eBay one that folks seemed happy with. Might try a search (I don't seem to be able to make that work as well as the experts do). I've got a couple BeCool units, but they're as pricey as the one you mentioned. They work though, at 90+ degrees, with a/c on.
Posts: 6.1K, Visits: 442.8K
Champion radiators
geo56
Supercharged (411 reputation)Supercharged (411 reputation)Supercharged (411 reputation)Supercharged (411 reputation)Supercharged (411 reputation)Supercharged (411 reputation)Supercharged (411 reputation)Supercharged (411 reputation)Supercharged (411 reputation)
Posts: 156, Visits: 6.7K
I bought a replacement aluminum radiator for my 56 Victoria with Fordomatic from Auto City Classic Inc. It has a stamped top and lower tank and was a direct bolt in replacement for the original. I needed to slot or drill nothing. The top tank, which was obviously die stamped , is a very good copy of the TBird type radiators of that era. I think the 312 equipped Fairlanes might have been equipped from the factory with the same type of larger top tank. It looks great, runs cool with the 13 pound cap , and cost $229.00 which was about half of what I paid for a brass replacement that leaked after a years time. I resisted an aluminum replacement and blew about $800.00 on a brass recore and the new brass replacement that also leaked at the top seam . Before I was referred to Auto City Classic, the only aluminum rerplacements I saw on Ebay looked like street rod radiators with the tanks made of pieces of aluminum flat bar welded together. After about 6 months of running cool and no leaks,I have not looked back.
George
lowrider
Posts: 479, Visits: 10.9K
X2 on Champion. Have one in my 57 and 61
Meandean
Supercharged (464 reputation)Supercharged (464 reputation)Supercharged (464 reputation)Supercharged (464 reputation)Supercharged (464 reputation)Supercharged (464 reputation)Supercharged (464 reputation)Supercharged (464 reputation)Supercharged (464 reputation)
Posts: 163, Visits: 137.7K
I also have one of the Auto City Classic Aluminum radiators and that along with a 6 blade fan did a lot to cause my 55 Fairlane to run in the middle of the temperature gauge and not keep creeping up to the hot line.  I think this is the 3rd or 4th year it's been installed and so far it's been a great purchase.
On my car the mounting height was just a bit of an issue as we noticed that the top of the radiator was a bit high and the cap would have hit the underside of the hood if we'd just slammed it shut.  A very minor bit of slotting the holes was necessary.  So if you go this route I'd advise you to check that.
Kahuna
Posts: 471, Visits: 2.4K
Champion also
Here’s the link to a recent thread discussing aluminum radiators.
http://forums.y-blocksforever.com/FindPost129567.aspx
62bigwindow
Posts: 884, Visits: 14.3K
Champion here also. I have one in my 56. No issues at all. One reason I chose them ,other than cost,was you can request your rad to me made in the USA. It will cost a bit more but worth it I think
Durham Missouri
I have a US Radiator from Los Angeles, it is copper/ brass and looks as original. They have many different tube/fin combinations and I had auto trans cooler placed in it. They list in places like Drive Magazine as Cool Craft and also make aluminum ones. It was reasonable and assembled in LA.
