Vally Pan Modifications
Posted By Richard 8 Years Ago
Did you mention those problems to him?  While valve cover interference would bother me, you're not trying to look stock with a cast valley cover.
John Didde
Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)Supercharged (84 reputation)
Posts: 37, Visits: 426
I agree there should be more clearance between the valley cover and thermostat housing, called John he said shouldn't be a problem. I didn't grind mine. will see as time goes on if there will be problem
Aaron
Normally aspirated (41 reputation)Normally aspirated (41 reputation)Normally aspirated (41 reputation)Normally aspirated (41 reputation)Normally aspirated (41 reputation)Normally aspirated (41 reputation)Normally aspirated (41 reputation)Normally aspirated (41 reputation)Normally aspirated (41 reputation)
Posts: 17, Visits: 3.0K
I just put one of Johns valley covers on, it cleared the thermostat housing, but as stated before the oil filler tube is at the wrong angle and with the alum T Bird valve covers the orginal push on cap doesn't fit, its even too small for the tube, I'm not sure what I'll do about it.
