Last Active: 4 days ago
My fix came from Greenbirds. It worked. I've never had a problem in traffic since I followed his fix. I did install the upper radiator shield to hood seal which made all the air from the front of the car go through the radiator prior to his fix on my 56 Victoria and it did help but it was cured by the pulley.
ronsplace
Visits: 630
Thanks, Charlie. I didn't realize it wouldn't work on my Fairlane. Ron...
The casco pump is for T-Birds, which have a 1" water pump spacer (which is a big part of their cooling problems) so it will not fit your Fairlane. The stock pump works perfectly fine as long as it is in good condition. Check coolant flow at idle, as already mentioned, and adjust as necessary.
ronsplace
Visits: 630
I see that CASCO has a "High Output" water pump that I spotted on page 29 of their 2016 catalog, part #8501HO. The price is set at $149 and includes a new gasket. Of interest, they also say they will modify owners' stock water pump for increased output for $50 (part #8501HOY). Seems that something like this along with a 5" or 6" down-sized pulley would bring the temp down to reasonable levels on hot days at idle with the a/c blowing. Has anyone installed one of these HO water pumps? Ron...
GREENBIRD56
Visits: 102.7K
Not only is the stock water pump flow pretty low at idle - but more so when in gear with an auto trans. Have a trusted soul sit at the wheel when you try this..... Water movement in my 'bird radiator (as seen through the radiator cap opening) was just about nil. In neutral, I revved the engine until the disturbance looked closer to what I used to see in my old '67 Cougar. It cooled just fine and I don't believe the waterpump was over-revved even at full throttle. The increased RPM level was a hint at how much smaller I was going to have to go to get the desired results.
Steve Metzger Tucson, Arizona
one piece at a time
Last Active: 5 Months Ago
Visits: 21.9K
My factory 3 belt ac water pump pulley measures 6 3/4" (1956 312 built in Texas) outside dimensions. I replaced it with an FE big block it measures 5 ".bolted right up. Had a heck of a time getting belts to work. Later discovered that flow kooler makes a high volume wp for the Y. 12 vanes vs 8. $170.00 spent that much on belts and the pulley.
Duane
Water pump RPM should be kept below 7000rpm. On a typical street engine, it will never exceed that rpm with even the smallest diameter pulley that can fit and it certainly will not happen at freeway speeds.
Posts: 1.9K,
Visits: 195.0K
Short answer, no. At least no one else has reported a problem. The water pump never moves enough water to be restricted by even the thermostat. If in doubt, fit one of the high flow stats for a mopar. Robert Shaw, can't remember the # right now. Others here will.
Greenbird56 has posted a great description of fitting a Hayden clutch and modified fan. He's in Tucson, and 110 degrees happens in the summer. Might do a search if you need to. The most important thing is a good shroud on whatever fan you use on the puller/radiator side.
ronsplace
Visits: 630
I have an electric puller fan that does the job until I hit slow traffic on a hot day. My stock water pump pulley is 7" in diameter as measured from the lips (not from the bottom of the groove) and I think I will install the 6" diameter pulley I have and see if that takes care of the over heating problem at idle. In the back of my mind, though, is whether this smaller diameter pulley is going to cause me problems at freeway speeds on long trips because of the increased pressure caused by the higher RPMs. Any thoughts on that? Thanks, Ron
Posts: 1.9K,
Visits: 195.0K
The smaller pulley is a pretty common fix, as is the bypass restrictor and the elimination of the w/p spacer on the bird's and spacing the pulley out to line up. Most aftermarket a/c kits come with an electric pusher fan for the unit out in front of the radiator. Got one of those? They normally aren't big enough to provide any engine/radiator cooling.
