Last Active: 4 days ago
Visits: 117
Hi has anyone got a CAD file for the bolt hole and dowel locations of the block where bellhousing bolts to? I can have my 272 put on the dyno if I can get this info for a motor plate to be laser cut. Much appreciated! Paul.
Visits: 16.7K
Paul sounds like you are working with a DTS dyno. This is what Ted has.. He probably has a pattern to make the motor plate
