55 sedan interior paint colors
Posted By tjaybo52 8 Years Ago
tjaybo52
Question Posted 8 Years Ago
Normally aspirated (32 reputation)Normally aspirated (32 reputation)Normally aspirated (32 reputation)Normally aspirated (32 reputation)Normally aspirated (32 reputation)Normally aspirated (32 reputation)Normally aspirated (32 reputation)Normally aspirated (32 reputation)Normally aspirated (32 reputation)
Posts: 13, Visits: 7.2K
Hi all, new to forum,
I have a 55 club sedan that I am restoring, the car is salmon and cream white two tone. I would like to know what the color code is for the interior trim above/top part of the dash I believe the rear window surrounds and the A-pillar covers are the same color. It appears to be a darker pink metallic but cant tell for sure. thanks in advance  Jim
Lou
Posts: 562, Visits: 8.3K
What are the paint codes on the data plate?
As I remember 55's were weird. Our 55 mountain green convertable had 2 different metallic greens on the dash and one stayed on the interior lower window frames but mountain green was a non metallic color. One thing you can try is once you have the data code colors for the exterior is to google it and hopefully some inter photos will come up. Good luck...
Posts: 3.6K, Visits: 497.7K
On your data plate you should have a letter(s) code under "Trim"  What are they?
tjaybo52
the color codes are K E
the trim code is J
56_Fairlane
Last Active: 9 Months Ago
Posts: 575, Visits: 14.6K
http://www.thecvaonline.com/howtos/DataPlateDecoder.pdf
~DJ~ AKA "Bleach"
tjaybo52
DJ, thanks for that code chart, I have seen it before, as far as I can tell it doesnt speak to the "3rd" color that the Interior has. All the steel trim pieces around the windows and top part of the dash are painted with what appears to be a darker metallic rose color. It is hard to tell as this car has been sitting outside for over 30 years. it has all the original paint and upholstery. I was hoping someone with  this same color scheme or familiar with it would chime in.   Cheers Jim
Lou
The sun and time  has faded the color, it was not painted a "Rose" color from the factory
56_Fairlane
Jim. I'm a little confused. You mention that your car is all original salmon and cream white two tone but according to the codes it should be "Buckskin brown and Snow Shoe white" with copper colored upholstery. You may want to check the trim that wasn't exposed to fading such as the back side of the trim.
I have to check if my trim books cover the 1955 models to see if there's more info shown.
~DJ~ AKA "Bleach"
56_Fairlane
OK. I can see how your car might appear to be salmon based on this 55 CV. Now I have to find some interior shots with your colors.
Here's a link to the same car with your interior colors but with slightly different materials.. http://www.oldforgemotorcars.com/vehicles/365/1955-ford-crown-victoria-fairlane
Image result for Buckskin brown and Snowshoe white
~DJ~ AKA "Bleach"
