rontron
Visits: 41
I'm changing out the old flex plate with rivets with the new type and the one I see on Macs that is supposed to do that looks square......I don't know how square fits in a round hole.
Ron Tron
Visits: 39.5K
If you can find one I would replace that one with a full circle style. The riveted ones are a source of problems. Chuck
rontron
Visits: 41
can you direct me to a new one that will fit?
Ron Tron
Visits: 39.5K
Maybe Carl Lynn, on this site can help. There are several people on here with a few y-blocks laying around. Hopefully one of them can help. Also check EBAY etc. I'll do some searching from this end too. If you do find one please post.
Visits: 498.3K
CASCO shows a flex plate for a Fordo, but it is marked for an air cooled. Is there a difference? I would start calling the Tbird part stores to see what they have. If not available new for what you have, try Hill's in Ohio as they have a lot of used parts.
rontron
Visits: 41
I found the flex plate on Macs automotive website..........I ordered it and now I need to know the torque setting for the 6 screw caps or bolts that hold it to the engine.........I have a shop manual but it doesn't list flex plate torque setting.......did they call the flex plate something different in 56 when the shop manual was printed?
Ron Tron
Visits: 39.5K
This is on EBAY today: http://www.ebay.com/itm/54-55-56-57-58-59-60-61-62-63-64-FORD-CAR-TRUCK-MERCURY-THUNDERBIRD-FLYWHEEL-/142328078514?hash=item21236a20b2:g:9~sAAOSw4A5Y2YGE&vxp=mtr
57RancheroJim
Visits: 112.0K
Thats a stick shift flywheel for a clutch????
Visits: 39.5K
I guess I just saw the picture and jumped too quickly. Typical, sorry if it got your hopes up.
Visits: 498.3K
Probably the same as a standard shift flywheel. Same size bolts were used but were shorter I assume. rontron (3/28/2017)
