adapt aod transmission into 1956 ford f-100 v 8
Posted By raywarr55 8 Years Ago
Posts: 4.6K, Visits: 38.5K
Can you use the old Hurst style mount in the front? I have one available. Chuck
  Image result for hurst y block motor mount
Outlaw56
Supercharged (926 reputation)Supercharged (926 reputation)Supercharged (926 reputation)Supercharged (926 reputation)Supercharged (926 reputation)Supercharged (926 reputation)Supercharged (926 reputation)Supercharged (926 reputation)Supercharged (926 reputation)
Posts: 436, Visits: 26.9K
Does it bolt to a Y block? It looks like the plate may intefere with the A/C bracket.
57RancheroJim
Posts: 729, Visits: 112.0K
You said you only have a 1/4 inch clearance, how much to you need? I'm lazy and would probably mount the body up a little higher on the frame  LOL
Outlaw56
I honestly dont know, but I know when you step on the gas,  most engines should have more than 1/4" clearance. I wont know for sure until I have it properly mounted and see what the tolerance is.
Posts: 1.9K, Visits: 194.9K
I'm not quite sure I understand where the interference is, but the side rods on the T-birds provide plenty of stability. FPA headers use a heim joint off the header flange. I don't know how they clear the rams horns, but you could make something work. There's at least one bird out there with the FPA set up that can pull a front wheel, that should be stable enough.
With that set up, I also think a 1/4" clearance to the tunnel would probably be ok. I've run drivetrains closer than that in some vehicles.
Outlaw56
Thanks miker. I dont think I need a lot, just a more than 1/4 for insurance.
Outlaw56
My thinking on modification of that main cross member was to remove it, place it in a jig and bolt it together just like it sits in the frame rails stock. Then cut the center section out and lengthen it so it looks stock, but has more clearance under the transmission,. If I lower the engine one inch, what kind of issues am I looking at with compatibility with stock radiator?
raywarr55
Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)
Posts: 5, Visits: 2.5K
hi moon shadow.
I do have two sets of 331 hemi heads.
(401)294-7599
thanks ray.
57RancheroJim
I doubt 1" would have much effect. Depending on the clearance between the bottom of the radiator and the support you could probably redrill the radiator mounting holes to move it down.
Outlaw56
I think 1" would help a lot.
