C0TE heads
Posted By repeater 8 Years Ago
repeater
Supercharged (82 reputation)Supercharged (82 reputation)Supercharged (82 reputation)Supercharged (82 reputation)Supercharged (82 reputation)Supercharged (82 reputation)Supercharged (82 reputation)Supercharged (82 reputation)Supercharged (82 reputation)
Posts: 30, Visits: 69
Does anyone know what the combustion chamber size is on these? On both Tim and John's site, the CC chamber size is blank. I just tore apart this 292 I'm going to build and I've got a C0TE head on one side, and a C1TE on the other. They look absolutely identical, so I'd assume 76CC like the C1TE? Just curious if anyone has actually measured.
carl
Last Active: 10 minutes ago
Posts: 1.2K, Visits: 20.6K
Check Ted Eatons site,he probably has that information on it    Carl
Using 75 or 76 cc’s as an arbitrary value will give you a rough idea but until you actually cc the heads, you’ll not know for sure.  It’s not unusual for the heads to be larger than advertised.  It’s also not unusual for the heads to have progressively larger (or smaller depending upon your perspective) chambers from one end of the head to the other.
repeater
Cool, thanks Ted.
