Visits: 2.5K
A friend of mine had me go with him to look at a 1954 Monarch Sun Valley. The Car has had an engine swap to a newer 312! What I was wondering is, did the Canadian cars have the same 256 ci engine that the American Mercury's had or did they have the 239 like the Fords engine as original engines? What are the engine codes for each engine?
Last Active: 5 hours ago
Posts: 3.6K,
Visits: 497.5K
Based on what I have read, the Canadian 54 Fords all had the 255 inch flathead
Visits: 1.7K
yes they had a 256 same as u.s. models.
Visits: 9.6K
I have a Canadian printout that I grabbed from someplace on the internet. It specs a code for the 49-54 Mercs as using an engine code on the data plate for the 255 L head engine as one of the following, 9C,OC,1C and OCB.
Interesting that the engine is a 256 in the USA and a 255 in Canada. Oldmics
Visits: 137.7K
Oldmics1 (2/3/2017)
I have a Canadian printout that I grabbed from someplace on the internet. It specs a code for the 49-54 Mercs as using an engine code on the data plate for the 255 L head engine as one of the following, 9C,OC,1C and OCB. Interesting that the engine is a 256 in the USA and a 255 in Canada. Oldmics A little bit of shrinkage is all. It's COLD up there.
Visits: 2.5K
OK thanks I will check with the owner of the car and get the engine codes off the car. I know the 1954 Fords built in Canada had the flat head engine. Every Mercury and Monarch I have seen had the over head Y block engine, I know the Y block was available in the Canadian Mercury For sure.
Visits: 1.7K
its a 256 overhead valve same as 54 mercury what part of that dont you understand.
Visits: 2.5K
314 (2/3/2017)
its a 256 overhead valve same as 54 mercury what part of that dont you understand. There were 4 people that commented , But the part I do understand is you don't need to be a rude ass!
Posts: 3.6K,
Visits: 497.5K
The flathead Merc engines, as I remember, had 255. something CI, while the YBlocks had 256. Not much of a difference. The flathead Fords and the Ford Yblocks both were 239.
And as far as I know, as I stated above and by Old Mics, the Canadian Fords and Merc's had the flathead engine, not the Yblock. Possible, I guess, that the Canadian Mercs had the YBlock but I doubt it.
Visits: 190.0K
1954 merc cars hadY blocks 256 ,i think they where all us bilt in the us 54. the un knowen was monarch.has to be a canadian out there that will advise..all 54 cars had the old frame and the flathead .55fords and meteors had new frame and 272Y blocks mixed info on trucks256 was common on v8sdo not know when 272 and 292 came on canadian pickups.
