Hi guys,
I am currently reassembling my Y block (272) after it came back from the machine shop. I have come across my first problem (guaranteed installer error).
Let me get this straight first... I'm no expert and I'm not pretending to be, I took on this tear down/rebuild to learn about engines and do it myself, so I had anticipated a few problems and the possibility of complete failure, but sometimes that's the best way to learn (unfortunately).
Anyway, had a friend turn down a cam bearing remove/install tool for me and it seemed to work pretty good. I installed a the bearings and put my old cam in to see if it fits and it did, until the last bearing. It spun fine by hand until the last bearing than I had to spin the cam using a rachet on the bolt. I even put the cam in the othe end of the block and it spun fine in the last two bearings (that was as far as the engine stand would let me). So I tried the new cam and it was the same.
So I figured it must be the last bearing that is not in square, so I checked and seemed to be equal measurements all round.
In conclusion, how much resistance is acceptable when spinning the cam? I saw a video of Tim McMaster installing cam bearings in like 2min and his cam spun easy.
Any help would be appreciated. Also I purchased my cam from John M so I'd imagine it would be in good condition.
Thanks.
Thanks, Dennis.
56 F100 - 272 Y Block
NSW, Australia.
