how long is your VIN?
Posted By texasmark1 8 Years Ago
texasmark1
Posts: 650, Visits: 2.7K
my 57 Fairlane has a 10 digit VIN...
searching for it, I keep getting "VIN must have 17 digits.
is my title missing something?
thanks,Mark
texasmark1
that title should be "VIN"...
Mark.  I think that 10 characters is the correct number.  Click the link below for an example on data plate decoding.
http://www.ctci.org/decoder.php
Hope this helps.   Smile
crownvic55
Supercharged (107 reputation)Supercharged (107 reputation)Supercharged (107 reputation)Supercharged (107 reputation)Supercharged (107 reputation)Supercharged (107 reputation)Supercharged (107 reputation)Supercharged (107 reputation)Supercharged (107 reputation)
Posts: 38, Visits: 154
Back then they weren't VIN numbers.  Not sure when they came into use.
Ben HessTulsa,OK
62bigwindow
Posts: 884, Visits: 14.3K
I'm pretty sure the 17 digit VIN is a more modern thing. My 56 has 10 also if I'm remembering correctly.
Durham Missouri
Posts: 3.6K, Visits: 497.7K
VIN's have been on Fords back to the Model T's
crownvic55 (1/21/2017)
Yesterday's terminology was 'vehicle serial number' found on the vehicle data plate.  I don't know about other makes, but on our vintage y-block Fords, that vehicle serial number is stamped on the vehicle frame in three specific locations.
More recent terminology for the vehicle serial number is VIN which is simply the acronym for 'vehicle identification number'.
Here's the link to the data plate decoder for our vintage Fords that decodes your vehicle serial number.   Smile
For the Fifties’ Fords, it’s normal for the VIN (serial number) on the data plate to only be ten digits long.  Here’s an excerpt from a page out of a VIN decoding book for the 1957 Ford showing the ten digits.  You’ll have to keep in mind that Ford put the identification number on the body and the frame but not on the engine.
http://forums.y-blocksforever.com/uploads/images/1eb50f57-4546-4eaf-9c2d-0e37.jpg
62bigwindow
One thing that always makes me chuckle is when you hear a vintage Ford as being numbers matching engine and transmission.
Durham Missouri
62bigwindow.  At first blush your statement is totally correct.  -There is no serial number on the y-block Ford engines or transmissions that corresponds to the vehicle serial number that it came out of.
For the purist however, there are engine component casting numbers AND some components have casting dates that are 'correct' for the vehicle the engine or transmission came from.  This also comes into play with transmissions.
I am not a numbers guy, but for someone putting together something like an E code or F code car, this information can affect the value of what they are restoring.
You are totally correct that the purists working on the restoration of something like a Corvette, this serial number stuff has got to be hard.   Hehe
