Visits: 97
converting the '55 Bird to better ignition system. Need the 1957 mechanical tach drive distributor.
Steve
Posts: 1.8K,
Visits: 194.2K
Steve. PM sent.
Visits: 9.6K
Visits: 1.7K
thinking of all the ones i could have had for little or nothing.57 merc turnpike cruiser used the 312 as base motor in canada.seen lots going to scrap back in 60s
Visits: 2.4K
Did the Mercury use a tach drive?
Visits: 1.7K
the turnpikes all did.
Posts: 1.8K,
Visits: 194.2K
Back in '68 I went into the usual junkyard I got parts from, and the owner showed me a tach drive 57 dist. Said it came out of an ex police car he'd taken in. He owned an F code 57 bird, and he liked me. I suppose because I was usually covered in grease and willing to listen to his advice. " I'll put it under the counter kid, let me know when you can come up with 25 bucks". Took me a month, but he held it for me. That's the only reference I ever heard to a police car with a tach.
Last Active: 9 hours ago
Visits: 113.4K
Greetings to all: The 57 Mercury Turnpike Cruiser did have a mechanical tach but every TC I have seen had the Lincoln 368 Y block. They may have been available with a 312 but I have never seen one in a TC. The 368 used the same distributor as the Ford Y but had a 15 tooth gear instead of a 14 tooth. About 4 years ago I was very lucky to find a 57 Merc tach drive dizzy from a 368 in excellent shape very cheap. Changed the gear to a 14 tooth and am using it to run the mechanical tach in my restored 64 F100. Sometimes it pays to look for the parts we want/need under totally different listings. Hope this helps, JEFF.........................
Visits: 9.6K
Interesting to note that in 1957 there were 2 different part numbers used for tach drive distributors in the Y Block engines. This does not take into account any dual quad or supercharger distributor units.
The 2 different tach drive distributor part numbers were slated as a B7S 12127 A and also a B7S 12127 D
Mercs , with the tachometer option 312 engines got the B7S 12127 D.
Thunderbirds (292 and 312s) could have gotten either the B7S 12127 A tach drive distributor OR the B7S 12127 D tach drive distributor units.
Curiously enough there was no specific tach drive distributor for the 292 engine. The B7S 12127 A was cast as FEJ 12127 A The B7S 12127 D was cast as FEK 12127 B
Oldmics
Visits: 97
Thanks for the information, this site and the Y-blockers are always helpful. Currently looks like my options are Oldmics rebuildable 1957 tachdrive for $950 and a new Mallory unit for $851. Still not sure which option i will take.
Steve
