Visits: 23.2K
Visits: 22.0K
My '55 Merc manual says SAE 90 for summer and winter above -10F, SAE 80 below -10. Capacity is 3 1/2 pints or pounds, maybe the same for your Ford. You can just fill it until it begins to seep out of the filler hole and you're good. I think I'd stick with what Henry said re: viscosity.
Last Active: 4 hours ago
Posts: 7.5K,
Visits: 205.8K
Shouldn’t make a difference but which style rear end do you have? You have your choice of the Ford dropout (third member style) or the Dana 44 (cover on the back). I use the 85W-140 in the 9” that’s in my ’55 Customline but this sees Texas heat much of the time.
Visits: 23.2K
Posts: 7.5K,
Visits: 205.8K
I just looked at my ’55 Ford owners’ manual and it states 3½ pints for the car rear and 3 pints for the station wagon rear. As all ’55 Ford station wagons I have dealt with had the Dana rear, then that should be the difference in rear end oil capacities.
