Visits: 20.6K
Finished parting out a 55 mercury today,lot of good used parts for sale,no good sheet metal left.Merc was a 2 door sedan 292 3 speed with overdrive and has a dana 4,09 rear end. Carl
Last Active: 4 days ago
Visits: 8.3K
Where are you?
Visits: 20.6K
I live close to Circleville Ohio,25 miles south of Columbus Carl
Posts: 2.0K,
Visits: 128.9K
Do you know which rear end it has?
Visits: 20.6K
Daniel Jessup (11/29/2016)
Do you know which rear end it has? it is a dana 45,4,09 ratio. Carl
Posts: 2.0K,
Visits: 128.9K
Ok thanks, any idea on what kind of shape it is in, or the mileage on the car?
Visits: 20.6K
Ok thanks, any idea on what kind of shape it is in, or the mileage on the car? Daniel the Merc rear end has been promised to another member.I have a Dana 44 with 4.09 gears that was removed from a running 56 Ford station wagon for sale though Carl
Visits: 239
iam looking for a good rear end and drive shaft for a t85 od in a 55 fairlane also seats for 2 door post
Visits: 20.6K
ted denny (1/28/2018)
iam looking for a good rear end and drive shaft for a t85 od in a 55 fairlane also seats for 2 door post where are you located Carl
Visits: 1.4K
Hi Carl, I was referred by another forum member, I am looking for the engine bars that go from the firewall to the fender's found on 56 4dr hdtps only. Any help is appreciated
