Visits: 3.5K
Just installed a new HEI distributor on my '56 Ford Crown Victoria's 312. Read that you are not required to use a gasket when you install the distributor. Dose this apply to new aluminum HEI's or only to the original Load-o-matic vacuum only distributor?
Posts: 7.4K,
Visits: 205.0K
Y-Blocks do not require a gasket at the base of the distributor body. Installing one can potentially raise the distributor gear enough at the cam gear that you don’t get the correct mesh. A bit of oil or anti-seize on the distributor may alleviate any seizing that may take place later where the distributor fits within the block.
Visits: 3.5K
Thanks Ted, The new HEI dizzy came with a gasket so I installed it only to read that it might not be necessary . The old load-o-matic dizzy had no gasket when it was removed. And by putting in the HEI with mechanical and vacuum advance, what a world of difference in performance.
Visits: 23.2K
Visits: 3.5K
Got a Pertonic 40K coil and seems to be doing great. Before I read your post about the gasket, I removed it. It, the gasket was very very thin. Probably should have left well enough alone
Visits: 340.0K
It sounds like you have already changed the carb from the one that's for the Loadmatic. If not Ted has a write up on how to make the older Holley compatable with newer distributors.
Visits: 23.2K
Visits: 441.8K
Most "HEI" distributors use an o-ring as a seal, similar to the later Motorcraft distributors. That gives you extra insurance, but you should have no problem without a gasket, either way.
