292 Head gasket question
Posted By Y me 9 Years Ago
Y me
Turbocharged (54 reputation)Turbocharged (54 reputation)Turbocharged (54 reputation)Turbocharged (54 reputation)Turbocharged (54 reputation)Turbocharged (54 reputation)Turbocharged (54 reputation)Turbocharged (54 reputation)Turbocharged (54 reputation)
Posts: 16, Visits: 1.1K
Is it possible oil is getting into #7 cylinder from headgasket. Engine burns oil from left pipe only ,#7 plug oily . When it smokes it's bad at idle . SOME times it doesn't smoke at all. never smokes at start up. Oil returns seam clear. Compression test apx.120 in all cylinders but I forgot to block open throttle. Vacuum gauge reads steady 20. I'M waiting on leak down gauge that's still on backorder. When engine is running it's smooth. No pressure in oil fill when running. It does have pcv valve and it's new , also oil cap is plumbed into air cleaner . OIL pressure was 60 lb when cold with 15w 40 , I tryed 20w 50 and pressure is 80 cold. Pump is new within a year. Smoking problem didn't change with thicker oil.
62 f100 short unibody 292 big back window massachusetts
Last Active: 15 hours ago
Posts: 7.4K, Visits: 205.0K
Steel shim or composition head gaskets?  Oil leakage into a cylinder is a possibility with a steel shim head gasket but haven’t seen it with the composition gaskets.  I’ll suggest a leak down test on the cylinder in question to help isolate the issue before pulling the head.
Y me
I believe it's steal shim. I did put shop air into cylider with piston tdc and I dId hear it through oil fill. how can I tell if it's getting past rings or through head gasket to oil passage.
55 GLASS TOP
Posts: 389, Visits: 31.8K
Is it possible he has a bad valve stem seal
aussiebill
Posts: 1.8K, Visits: 11.4K
55 GLASS TOP (10/28/2016)
No
 Down Under, Australia
55 GLASS TOP
Why not
