Disc Brakes on an early F100
Posted By pegleg 17 Years Ago
Glen Henderson
Posted 17 Years Ago
Posts: 1.4K, Visits: 7.5K
Frank, I'm late with replying, but I got the brackets for my 62 F100 from Classic Performance Products (714) 522-2000 in Anaheim, CA. The kit has brackets and mounting hardware, uses 70's ford rotors and GM calipers. The kit is $85.00, I got the rotors , loaded calipers, bearings and duel master cyl form CarQuest. Works Great!
Glen Henderson
Freedom is not Free
Letohatchee, AL
Posted 17 Years Ago
Bill.
      I did put a 1/16" toe in on the Ranger and it did get better, but still wanders some. I have a set of AIM 2 1/2" dropped axles on it, they weren't very accurate. We had to shim and bend to get them useable, still has too much negative caster. Had to put a shim under the springs to raise the nose to help that.
       Also Bill, your roads are a ton better than ours, we have frost and freezing issue along with the potholes. It was 38 here LAST NIGHT!! w00t
yehaabill
Posted 17 Years Ago
Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)Supercharged (468 reputation)
Posts: 426, Visits: 1.4K
Frank Y-Guy again:
                  On the ranger deal, I've had several and the alignment
           spec's call for zero toe, I put about a 1/16 in on mine and you
           can drive it 75 with one hand.
                   My thinking is that with a little bearing wear,ball joint wear,
           it's actually toe-ing out going down the road and causes the problem
           you're describing... Hope this helps  Bill
Bill
Pelham,Al
yehaabill
Posted 17 Years Ago
Frank Y-Guy: I just put disc on my '60 F-100 but, I wanted the 5/41/2
                   pattern. Got the kit from ABS co out,of you know where,
                   that foreign country called California, installed it in hour or
                   so, only problem they used the re-drill rotor deal so the wheels
                   didn't fit so well the first time. I was afraid of them being
                   out of round, but it rode "smooth as glass", so I'm happy
                   with it.(I did email them to tell them to use a "dummy" wheel
                    for their pattern next time!         Talk with you soon, Bill
Bill
Pelham,Al
55Birdman
Posted 17 Years Ago
Posts: 1.0K, Visits: 4.5K
Contact MPBrakes in Mooresville NC they have disc kits for Ford trucks. 1 888 249-9424 www.mpbrakes.com
55Birdman Smile  Hickory NC
Posted 17 Years Ago
I know the later, two wheel drive stuff, uses the goofy swing axle arrangement. Twin I beam.  My Ranger has one of those, the discs work well, but that truck doesn't weigh much.The one thing I really dislike about it is the truck follows the channels and bumps in the road. You have to drive it ALL the time. Not a problem on the strip or on a decent 4 lane. I am pretty sure the Twin I uses a king pin setup, But i don't have any idea of it's compatibility with the earlier F series I beams. Undoubtedly they've changed all the dimensions from the Fifties. You'd think they'd be bigger and stronger on the newer, bigger and heavier with better brakes, F150's.
       Anyhow, thanks for the answers, I'll pass the information along and tell him to register on the forum, maybe we can convince him to build a Y. His last project was a supercharged (Wisconsin) garden tractor for garden tractor pulling. Prior to that he built a four engined version, with four little Honda 2 1/2 hp (ea) engines. Now that was wierd! Sure sounded neat though.
Posted 17 Years Ago
Posts: 6.1K, Visits: 442.9K
There are companies which make kits to mount rotors and calipers to these older trucks.  I happen to have an ECI kit installed up front which uses the 73 to 93 F100 and F150 rotors, 5 x 5 1/2 pattern, and GM calipers.  It looks like they have 4 1/2 and 4 3/4 options as well.  Mine have worked well so far.  I did not do the install nor have I yet had to service them, so I am of no help there.  I wish I could find a 5 x 5 1/2 rear setup with parts I can pick up at the local parts store - most of the kits available for this have redrilled or proprietary rotors.
PWH42
Posted 17 Years Ago
Posts: 854, Visits: 6.0K
Just curious:Has anyone ever adapted a Twin I-beam from a later F series or Ranger to a 50's F-100?This would provide the disc brakes if it can be done.
Paul,
Boonville,MO
Posted 17 Years Ago
Posts: 3.7K, Visits: 323.1K
Frank:
If he still has the original front suspension, it has king pins.  I don't know of any factory putting discs on a kingpin front end.  He may be looking at a frame clip of some kind to get disc brakes.
John
Posted 17 Years Ago
Posts: 3.6K, Visits: 497.7K
Check with ECI (Engineered Components) in Conn - they may have a kit.
