Lifters again
Posted By LordMrFord 9 Years Ago
LordMrFord
Posts: 687, Visits: 9.3K
Lifters are 0.4975-0.498"
Hyvinkää, FI
Be sure to check the tappet stem diameters.  There are lifters out there that do not have adequate oil clearance within their bores.  Any stems measuring greater than 0.4990” on a Y can pose a problem in being too tight within the lifter bores.  If they do not turn freely when at operating temperatures, then lobe/tappet failures will take place.  This is simply one more thing to check when assembling an engine.  "Assume nothing".
LordMrFord
Trend's might be good but cost over four cam regrouds + few cheaper lifters in here, other side of planet so if pulling engine off and back again dont start to bother me too much, I try to go cheaper way first.
I think dragster got Comp lifters also, huge spring pressures and over three times more power than my engine and got now first cam failure after hundreds of cam rocking quarter mile pulls, problem might not be lifters but me.
But thanks for the advises again. Now I'm a little bit wiser and recognize my faults better.
Hyvinkää, FI
314
Posts: 287, Visits: 1.7K
if steel lifters are the best what about ford early steel lifters.
speedpro56
Posts: 1.3K, Visits: 9.2K
Trend tool steel lifters tend to be the best and worth the investment. Been there done that and don't need to say no more!
-Gary Burnette-
Cliff
Posts: 878, Visits: 13.5K
Hi, have you used Trend Tool Steel lifters?
LordMrFord
I have to double check that pushrod thing.
Hyvinkää, FI
There has to be a couple of camshaft lobes that are far from pretty with lifters looking like that.  Ouch.
One of Randy Gummelts’ engines broke the head off the tappet like that and the root cause was traced back to the pushrod being too large in diameter and was rubbing within the pushrod hole in the cylinder head.
LordMrFord
Cliff (10/26/2016)
What lifters are you using?
Those are Comp Cams lifters and cam is Schneider. Engine is runned few hours.
Starter didnt work properly when I got engine ready and there was maybe too much starting in the beginning.
Head gasket also blew sortly after break in and engine was full of water.
Hyvinkää, FI
Last Active: 2 Weeks Ago
Posts: 1.9K, Visits: 194.9K
I lost a lifter like that last year. Found the pieces in the pan. No abnormal wear on the pieces, or any of the other lifters, or other lobes. 7 years, 6000 miles, not over 5000 rpm. Figured it was a freak failure. Sure took that lobe out though.
