My Harley came with DOT-5, but NONE of my factory Ford cars used it. In fact, none of the OEM's fill with DOT-5. The reason being, nothing works better than DOT-3 for an occasional or daily driver.
We can talk about seal-type incompatibility, spongy pedal, water, or air issues if you like. Brakes are THE MOST IMPORTANT SAFETY ISSUE in every vehicle, and VERY susceptible to law suits. If DOT-anything was better than DOT-3, believe me, the big three would have it in all their cars. The whole system only holds ~a cup! The cost difference isn't very much to an OEM (compared to one negligence judgment in court).
Be careful filling your DOT-3 because it does eat paint. It easily washes off with water. If you decide on using DOT-5.1, remember it is still glycol based so have wash-water available.
Consider the mechanics involved with every cylinder application where air is on one side of the piston, and a liquid on the other; master cylinders and wheel cylinders. DOT-3 is 600 times more dense than air. That's why it seals so well. When a seal moves over a bore, the liquid fills all those tiny tool marks and helps lubricate the action. When retracted, the liquid in those tiny score marks picks up water in the air. The next time the seal slides over, new fluid mixes with the saturated fluid and it disburses with all the fluid. Over years of use, the system becomes saturated with water. There is no such thing as a "perfect" seal and normal brake system pressures operate between 600-2,000 psi. Serious pressure!
One way to reduce this problem is by limiting piston motion. Disk brakes don't retract their stroke, which greatly reduces fluid saturation. Drum brakes can be fitted with "Residual Valves" which always maintains ten psi line pressure. That stops shoes from retracting all the way, and it keeps the brake pedal (M/C) at the top of its stroke, further reducing saturation.
Dave Dare
Royal Oak, Michigan (Four miles north of Detroit, and 12 miles NORTH of Windsor, Canada). That's right, we're north of Canada.Ford 292 Y-Block major overhaul by simplyconnected
