By rgrove - 18 Years Ago
Well, I discovered yesterdayt hat me master cylinder is leaking on the firewall, ruining the paint, etc. Frankly, Im sick of bleeding brakes (usually do it every 2 years - was going to get started when I found the issue). Does anybody have any 1st hadn experience with silicone brake fluid? There is a lot of anectodal info on line, etc. but does anybody have the facts about using it for a summer driver? Thoughts? THANKS IN ADVANCE
By bird55 - 18 Years Ago
I converted years ago, specifically because of the stripped paint issue. I have had no problems whatsoever with it.
By sundance241 - 18 Years Ago
I have converted a number of old fords , it does not remove paint from any small leaks.....the only problem i have found , if you have an in line brke lite switch, it will only last about 4 months , even tried low pressure switches , the same problem..........Had to change to an electrical switch off the brake pedel .........works great , with no other problems .....Sam
I have had problems in both my T-Birds, in addition to the brake switch issue. Silicone fluid will not absorb moisture. The moisture (it's in the air) looks for the lowest point in the system, the brake cylinders. Rusts the cylinders, and they stick. Dot 3 fluid absorbs moisture, and if we change the fluid every couple of years (I know, hardly anyone does that) the moisture is removed. Silicone will also find a smaller escape path than glycol fluid too. I switched back. By the way, I have heard that Harley Davidson has a brake light switch that fits old Fords and is silicon fluid tolerant. John in Selma, IN
By DANIEL TINDER - 18 Years Ago
rgrove,
Do you have a pressure-jug bleeder? It sure simplifies the process. I used an old master cylinder cap to make an adapter for the pump-up jug sold by Eastwood, etc..
John,
Just curious, but when you were running silicon, did you notice a softer pedal? I have heard it absorbs air, though the '90 Harley Sportster I had for 5 years had no obvious problem with brakes (except the single disc was inadequate for it's weight).
Dan: Yes, I noticed a softer pedal, kept thinking I didn't get it bled properly. By the way, it would have been 8 or so years after I installed the fluid that I had the brake problems. But I had serious rust pits in the master and wheel cylinders, as well as the stuck pistons. I guess after the cylinder bores got some pits, the fluid and water was able to seep past the cups to the pistons, where they corroded and stuck. These were cars that got driven every summer and parked every winter. John
By paul2748 - 18 Years Ago
I have silicone fluid in my 302 powered 48 - been there for twenty years and never had a problem with rust or leakage.
By Ted - 18 Years Ago
I use the Dot 5 fluid (silicone based) on all my drag cars and have been using it in my ’55 Customline since 1991. Ditto on the hydraulic pressure switches and I simply changed my ’55 over to a mechanical switch under the dash. I’ve redone the brakes once in the ’55 since switching it over to Dot 5 fluid and was pleased to find all the wheel cylinders very clean with absolutely no indication of the sludge that builds up when using the Dot 3 fluid. As has been said, it’s important to have a clean and purged system when switching over.
THANKS for all of the responses! Of the 3 restoration shops that Ive called, all of which I know/trust, 1 says silicone, 1 says dot 3, and 1 says silicone ONLY if you are willing to rebuild everything. I think the one thing I learned that surpised me a bit is that even if you switch, you still should flush it every few years due to potential water accumulation/pooling. I had assumed that if I changed that I would never have to bleed brakes again.... dare to dream... I do have a power bleeder that I just picked up... maybe ill see if that makes life much easier. I know that I could flush the lines, rebuild the cylinders, and replace the master cylinder (due to be replaced anyways) and the soft lines, but not sure how effectively I can flush the power brake booster..... I guess Im still a bit undecided for now...This seems to be like the great ZDDP debate - a lot of opinions, some people with good experience, but hard to find objective info.... Thanks again to all who replied....this forum is absolutely fantastic - I really appreciate all of the knowledge and people who are willing to share it!
57 Ford Kustom (5/25/2008)
Rgrove Unless you have a different power brake booster than most are there is no brake fluid in the booster T M It is the OE style booster....I was thinking of the piston assy connected with it.... it is really different than a typical "modern" booster. It actually mounts on the front inner fender, and has what effectively is another cylinder with a vacuum booster attached to it. THere is a hard line that connects the master cyl to the booster, then another from the booster to the distribution block on the frame.... its really a weird setup. Anyways, my comments were around cleaning/flushing the hydraulic part of the booster... sorry for the confusion!
By Ted - 17 Years Ago
I’m adding to this older post rather than continue the discussion regarding Dot 5 fluids that was started in the wheel cylinder installation post. Doing a search on this site using Dot 5 or Silicone brake fluid will also bring up other discussions on the subject. From experience I can only warn you to completely clean a brake system thoroughly if switching from one type of brake fluid to another. For myself, converting to Dot 5 fluid was analagous to switching from points to breakerless ignitions. Started using these fluids in the early Eighties and have used them on every complete brake rebuild since. But I do tag each master cylinder lid on each car that has it with a metal label specifying that the system is equipped with Dot 5 fluid. The US Military uses Dot 5 due to its non-hygroscopic nature. And as has already been mentioned, it is the factory supplied brake fluid in the Harley Davidson motorcycles. Scores of Corvettes out there with Dot 5 fluid and I’m aware of at least one dealership that has a program to retrofit those not with Dot 5 with it. It’s a given that there are many warnings out there not to use Dot 5 in cars that were originally equipped with Dot 3 or 4 fluids simply due to the incompatibility issues between the glycol based and silicone fluids. Dot 5 is not the cureall for all braking woes but for myself the positives outweigh the negatives and subsequently makes it the brake fluid of choice for myself. For the vintage car crowd, Dot 5 brake fluid does greatly minimize the degradation that occurs as a result of moisture hydration that takes place when using Dot 3 & 4 fluids. And the Dot 5 fluids are much more capable of longer intervals between brake fluid changes. Water pooling with Dot 5 fluid is not an issue if due diligence is taken in not washing down the engine compartment and flooding the master cylinder with water. Air entrapment is another issue though as pumping the brakes repeatedly can pull air into the fluid and make for a spongy pedal. I have good solid pedals on all my vehicles but also make it a point to use good brake lines throughout. Older brake lines will give that spongy feel regardless of the fluid type being used. A new generation of Dot 5 (5.1) fluids are now on the market which are glycol based rather than the silicone based fluids that have been around for awhile. The glycol based formula is designed to have less of an air entrapment within it thus making it more suitable for proportioning valve equipped systems. I haven’t had an opportunity to test this newest generation of brake fluid but with a new (old) car going together, it’s an opportunity I’ll consider. I haven’t had any issues with the original silicone based Dot 5 fluid so I have to question if I want to add another brake fluid type into the fray. Not trying to sell anyone on switching to Dot 5 fluids, just letting you know that I use it extensively without any problems. Feel free to add comments.
By simplyconnected - 17 Years Ago
My Harley came with DOT-5, but NONE of my factory Ford cars used it. In fact, none of the OEM's fill with DOT-5. The reason being, nothing works better than DOT-3 for an occasional or daily driver.
We can talk about seal-type incompatibility, spongy pedal, water, or air issues if you like. Brakes are THE MOST IMPORTANT SAFETY ISSUE in every vehicle, and VERY susceptible to law suits. If DOT-anything was better than DOT-3, believe me, the big three would have it in all their cars. The whole system only holds ~a cup! The cost difference isn't very much to an OEM (compared to one negligence judgment in court). Be careful filling your DOT-3 because it does eat paint. It easily washes off with water. If you decide on using DOT-5.1, remember it is still glycol based so have wash-water available. Consider the mechanics involved with every cylinder application where air is on one side of the piston, and a liquid on the other; master cylinders and wheel cylinders. DOT-3 is 600 times more dense than air. That's why it seals so well. When a seal moves over a bore, the liquid fills all those tiny tool marks and helps lubricate the action. When retracted, the liquid in those tiny score marks picks up water in the air. The next time the seal slides over, new fluid mixes with the saturated fluid and it disburses with all the fluid. Over years of use, the system becomes saturated with water. There is no such thing as a "perfect" seal and normal brake system pressures operate between 600-2,000 psi. Serious pressure! One way to reduce this problem is by limiting piston motion. Disk brakes don't retract their stroke, which greatly reduces fluid saturation. Drum brakes can be fitted with "Residual Valves" which always maintains ten psi line pressure. That stops shoes from retracting all the way, and it keeps the brake pedal (M/C) at the top of its stroke, further reducing saturation. Dave Dare
