Visits: 441.8K
I think it is a nippondesno motor, which I believe is Japanese. It's definitely a different sound. I may have been unlucky, but after going through 2 starter rebuilds and 1 generator rebuild with none of those lasting more than a year, I decided those vintage electronics weren't for me. The rebuilds were carried out by 3 different shops, two local, one in a different state, so that eliminates the shop as the problem. My conclusion is that the parts or expertise is lacking to properly rebuild them, so they put them together as best they can. Since making the swap to the modern starter (and alternator) that system of the truck has been trouble free.
Lord Gaga
Visits: 183.3K
Don't those minis make that chincy mopar/jap noise?? I'd rather eat worms! lol. In 50 years of Y Block experience, I've never had starter problems! Am I just lucky?
"FREE SAMPLE"
Visits: 441.8K
Sacrificing sound for reliability is worth it for me. Mine is a daily driver and I like it to start when I want it to start.
snowcone
Visits: 5.9K
And you miss out on that wonderful Y block cranking sound that no other car makes
Gary - 1958 Star Customline and 1940 Ford Deluxe Hotrod
Posts: 3.6K,
Visits: 497.5K
Got mine here http://www.autoelec.com/
brokengate
Visits: 6.3K
I installed a mini starter a few years ago, and in this context (yblock) mini is an accurate description of size, about half length and weight if I remember correctly, also easily installed. What did occur on one occasion is that the starter spun without engaging the flywheel, from my youth and worn out 57 fords, I put it in gear, push bumped it, and away we went. Although I haven't checked I assumed that I likely had worn tooth and/or the ring gear may previously had been flipped, as the original starter had never failed. I purchased mine from Automotive Electric, Negaunee, MI, 906-475-7772, paid $256.50, shipped in 2012. Hope this helps, don't drive it a lot so can't speak to longevity.
Ted, Redding, CA
Posts: 3.3K,
Visits: 238.8K
Mini is only a general description, so what make or makes have been used successfully for 8years or so ?
Posts: 3.6K,
Visits: 497.5K
I have one in my 312 powered 54. Been on for about 8 years. No problems at all.
Rono
Posts: 1.3K,
Visits: 80.0K
I've been using one of the mini starters for about 8 years without any issues. Yes, the starter drive engages from the front and there are only 2 mounting locations. I didn't use the rubber "splash" gasket which really isn't needed and it's still working fine. Also much lighter than the original. Rono
Ron Lane, Meridian, ID
rick55
Visits: 4.4K
I bought and fitted a mini starter to my 55 when I first got it going but was always worried about the mounting flange. It only used two bolts but it did not support the starter mounting in the opening in the bell housing, with only the ears where the bolts were contacting the bell housing. I hope that makes sense to you. It didn't seem to me that it was the best way to mount the starter and I doubted its longevity. I took it out and replaced it with the original though it was a real PITA to get in.
Rick - West Australia Do Y Blocks Downunder run upside down? Gravity Sucks!!
