Posts: 2.0K,
Visits: 130.3K
Anyone have a couple of extra sockets for a 1955 Ford backup light housing? I've got everything but the sockets. thanks Dan Jessup Loveland, Ohio 45140
Visits: 853
Rockauto.com sells a Dorman Part #85807 universal with backing plate 2 wire socket, $2.16 plus shipping each. They list others in their tools & universal parts, electrical- bulb & socket, universal socket section . Being a Dorman part you should be able to find just about any parts store, lots of them sell Dorman products. Looking at them for a project of mine, a friend recommended them to me. Maybe this will help, good luck.
Posts: 2.0K,
Visits: 130.3K
Thanks for the heads up I will take a look
Visits: 4.0K
It seems as though the 55-6 sockets are much larger than usual and therefore hard to find. I just looked in my Larry's Thunderbird catalog and they have the pigtail for the 55-6, but the whole assembly for the 57. It might be a one only application, but there are enough 55-6 cars and 'Birds out there, somebody should have a pair or at least one. I got lucky and my local Pick-n-pull had a 56 mostly parted out and the sockets were the only thing I could find that was useful. FWIW, I've used the same sockets in both 55 and 56 housings.
Don
Posts: 2.0K,
Visits: 130.3K
Thanks Don, that is good information to know. I guess I will take the housing down to the local auto parts store and have a look see. When I look at catalogs like Larry's Thunderbird, most do not even list the socket. If they do have a socket it always come with the wiring pigtail (which is single by the way). I do have a new pig tail for each side, just need those metal sockets that would house the actual bulb.
Visits: 20.6K
Daniel I have the sockets you need,send me a pm if you are still looking Carl
Visits: 20.6K
Daniel I sent you a message to your e mail address,couldnt get a pm here to go through Carl
