Adjustable vacuum advance canister
Posted By ianmatt 10 Years Ago
Posted 10 Years Ago
Posts: 3.8K, Visits: 33.4K
What Distributor are You using? The Standard Exchange Units have an Advance Can that is adjustable using an Allen Key through the Vacuum fitting on the Can (If you don't have the Type described by Steve.
GREENBIRD56
Posted 10 Years Ago
Posts: 1.7K, Visits: 102.7K
Does your distributor have the large Hex Nut looking fitting where the vacuum line connects? Those units will un-screw off the pot housing and there are shims there  to set the spring preload.
I've got mine at 7 degrees full vacuum can advance, 26 degrees of centrifugal and the initial at 10. That nets an idle advance of 17 and the stock cammed engine likes that just fine.
ianmatt
Question Posted 10 Years Ago
Supercharged (254 reputation)Supercharged (254 reputation)Supercharged (254 reputation)Supercharged (254 reputation)Supercharged (254 reputation)Supercharged (254 reputation)Supercharged (254 reputation)Supercharged (254 reputation)Supercharged (254 reputation)
Posts: 96, Visits: 443
Surprisingly i am not finding a part number online for an adjustable vacuum advance fir the dizzy on my built 292. I have too much advance with manifold vacuum at idle. Thoughts? Part numbers? thanks guys
