Oil Pump
Posted By rontron 10 Years Ago
Last Active: 29 minutes ago
Posts: 4.6K, Visits: 39.3K
Nice looking truck. I think (hope) you are on the right track with the flex plate. They can be very noisy. The oil pan removal is a chore but glad you got it off. I'm not sure how to proceed after replacing the flex plate though. It would be terrible to replace it and find you still have a knock. Did you pull the main caps and check the bearings for wear? Maybe some of the engine builders can weigh in on a way to check out the rotating assembly without disassembly. Good luck with it.
