hard brake pedal and no front brakes
Posted By Dave V 9 Years Ago
Dave V
Supercharged (457 reputation)Supercharged (457 reputation)Supercharged (457 reputation)Supercharged (457 reputation)Supercharged (457 reputation)Supercharged (457 reputation)Supercharged (457 reputation)Supercharged (457 reputation)Supercharged (457 reputation)
Posts: 233, Visits: 41.3K
What would cause my brake pedal to get hard and no front brakes on my 56 Fairlane with all manual drum brakes? I tried a new master cylinder and new front shoes which were glazed. The pedal is still rock hard and no front brakes. Dave V
SE Wis
62bigwindow
Posts: 884, Visits: 14.3K
Did you try to bleed the fronts? Almost sounds like a blockage in the line somewhere.
Durham Missouri
Dave V
Yes, I did bleed the front ones with a hand pump (syphon bleeder) and fluid flowed well.  DaveV
SE Wis
carl
Last Active: 6 hours ago
Posts: 1.2K, Visits: 20.6K
Sounds like you might have a blockage in the master cylinder  Carl
62bigwindow
Just throwing this out there but are the wheel cylinders moving like they should?
Durham Missouri
57RancheroJim
Posts: 729, Visits: 112.0K
Frozen cylinders was my thought also. Remove the drum and have someone push the brake pedal slowly and check for movement..
Small block
Posts: 90, Visits: 2.5K
I had this problem  on  a Ford  pickup after it sat over the winter, What was  wrong  with it is it had a ring of corrosion inside the Wheel cylinders
Causing them to only travel half the distance it took to apply the brakes!  I don't know why the  peddle gets hard when this happens but my truck elt like stepping on  a rock!
Posts: 3.6K, Visits: 497.5K
Disconnect the front brake lines and slowly depress the brake pedal a little bit to make sure the master cylinder is pumping.,  If so, then pull the wheel cylinders and remove the cups to see if the plungers are stuck.
Dave V
I also wondered about the wheel cylinders but don't understand why both would seize up at the same time.  I did order them yesterday and will be installing them tomorrow (Sunday).  Will post the results. Thanks for all the input.  Dave V
SE Wis
carl
I know you said you put a new master cylinder on but it sounds like the small bleed hole is plugged.There is two holes in the bottom of the reservoir,a large one in the rear and a smaller one just forward ,the large one lets fluid to the piston and the smaller one lets fluid return when you let off the brakes,I had the small one plug up with crud a couple years ago and it did exactly what yours is doing   Carl
