Brake bleeding procedure with power Brakes
Posted By Kahuna 9 Years Ago
Kahuna
Posts: 471, Visits: 2.4K
I am adding a Hydrovac unit to my 56 Ford (Like a Midland),
and would like to know if there is a specific procedure to
bleed the brakes?
Some one mentioned that the engine may have to be
running, but wasn't sure.
I thinking bleeding the Master Cylinder to the Hydrovac,
then bleeding the rest of the system in the normal fashion
would be OK
Anyone here have any experience with these things?
Thank you and sorry for all the questions
Jim
Last Active: 4 days ago
Posts: 1.8K, Visits: 190.6K
I googled "midland hydrovac" and what I got looked pretty much like the OEM remote booster on my 55 bird. You bleed the master to the unit, mine had a bleed fitting just like a brake cylinder. Then we bled the brakes as usual, farthest away first. Didn't need to start the engine, I wouldn't. Better control for a slow push without the diaphragm.
I suppose if it's a dual unit and a dual master, it's be the same, just back half then front to the booster, then rear then front brakes.
Kahuna
Thanks so much, Miker
I really app[reciate the information
Jim
