My Fairlane Steamed Out
Posted By Half-dude 9 Years Ago
Half-dude
Supercharged (597 reputation)Supercharged (597 reputation)Supercharged (597 reputation)Supercharged (597 reputation)Supercharged (597 reputation)Supercharged (597 reputation)Supercharged (597 reputation)Supercharged (597 reputation)Supercharged (597 reputation)
Posts: 227, Visits: 11.3K
Hey guys,
Well some news, my 55 erupted with steam getting off the highway a couple days ago after a lot of driving on and off all evening. Thankfully I'd just got off the highway and there was a large shoulder to pull off onto just to the right of the exit, got her turned off and let the engine cool down.
Turns out after looking into it the next day, the original radiator cap was basically holding NO pressure in the system , seriously we rented a tester and the needle would go up and immediately back down again. Got it replaced with a new 13pound cap with safety lever. So now we're hoping that the radiator actually steamed out before the engine had any time to actually start overheating.
I've had her running and driving a few times since, a few miles or so and back. The engine starts and runs fine, we also tested pressure on the coolant system and it's fine. Other then any avice you guys might have, I just have one issue.
The oil light on the dashboard came on and stays on ever since that night. It wasn't on when we were driving prior to the steam-out.. so if it did come on it must have came on right when we pulled over.
I'm figuring it's a false reading, the engine runs and I've been told if there was no oil pressure it'd be clacking like hell under the valve covers.. which its not. Could the hot steam under the hood have damaged the oil sender? Or would the light come on if the wire from the sender had melted against the engine somewhere and maybe grounded to it? Just wondering if it's a common symptom after an overheat.
Threaded View
Threaded View
Forum Post My Fairlane Steamed Out By Half-dude ( 9 Years Ago )
Forum Post If your radiator isn't new, I'd be afraid of a 13 lb cap. Maybe 7 lb. By pintoplumber ( 9 Years Ago )
Forum Post Bad wiring can certainly cause problems. Check it. Get a known to be... By charliemccraney ( 9 Years Ago )
Forum Post Charlie’s advice is spot on. The oil light staying on means do not... By Ted ( 9 Years Ago )
Forum Post Can I just take off the valve covers and see if they're oiling? By Half-dude ( 9 Years Ago )
Forum Post Hey, thanks for the detailed reply. Maybe I need to rephrase what I... By Half-dude ( 9 Years Ago )
Forum Post if you have an old/original radiator and hoses or have the factory... By HoLun ( 9 Years Ago )
Forum Post [quote][b]Half-dude (7/22/2016)[/b][hr] The oil light on the... By HoLun ( 9 Years Ago )
Forum Post It has the original radiator, but the hoses, thermostat, and gaskets... By Half-dude ( 9 Years Ago )
Forum Post Just my two cents, but I wouldn't drive it anywhere until you figured... By Daniel Jessup ( 9 Years Ago )
Forum Post definitely figure out your oil pressure issue before going any... By HoLun ( 9 Years Ago )
Forum Post Don't worry, I'll look into the issue first thing tomorrow before any... By Half-dude ( 9 Years Ago )
Forum Post Well, I worked on the 55 today. It was just a wiring problem, when I... By Half-dude ( 9 Years Ago )
Forum Post I changed the Water Pump Pulley on mine to One which is 6 7/8 Diameter... By oldcarmark ( 9 Years Ago )
Forum Post The bolt pattern is very common. A pulley from any other application,... By charliemccraney ( 9 Years Ago )
Forum Post One thing to remember, almost all the block and head passages may have... By miker ( 9 Years Ago )
Forum Post Which is true, it didn't come on until then, or the conditions to make... By Half-dude ( 9 Years Ago )
Forum Post I think its true that most of our vehicles were heat resistant in... By GREENBIRD56 ( 9 Years Ago )
Forum Post Sorry to disagree - but I do...... my Thunderbird - in good mechanical... By GREENBIRD56 ( 9 Years Ago )
Forum Post The other thing I"d add is to go buy an inexpensive infrared... By miker ( 9 Years Ago )
Forum Post Nice, I like the back and forth discussion. I have one thing to add.... By Half-dude ( 9 Years Ago )
Forum Post Roger, One of the problems with our 'birds is getting the air out... By miker ( 9 Years Ago )
