Rear wheel bearings ..........
Posted By 82warren 9 Years Ago
82warren
Supercharged (156 reputation)Supercharged (156 reputation)Supercharged (156 reputation)Supercharged (156 reputation)Supercharged (156 reputation)Supercharged (156 reputation)Supercharged (156 reputation)Supercharged (156 reputation)Supercharged (156 reputation)
Posts: 51, Visits: 84
On a trip to PA from MN to a wedding in our '54, a rear wheel bearing puked it's guts, we were lucky to find an axle, replaced it and came on home.
I got busy last week, bought two complete bearings on eBay, pulled my axles out, cut the retainer rings off then pulled the bearings off with a big puller I made, this worked really good, takes a lot of pressure to remove these things.
Then using my 12 ton press, carefully pressed each one on, I would estimate it took 5 tons to push them on.  The retainer rings took even more pressure, probably 8 tons or so but we got them into place against the bearings tight.  This friction is all that holds the bearings in place
and the only thing that keeps your axles in the car.
I used gasket maker on the plates that hold the bearings & axle in, also made sure the drain holes in the backing plates were open.
So, now we have all new rear wheel bearings, our long trip out west in
August should go a lot better, at least we hope so.
A big THANKS to all the guys that gave help with parts and advice, us Y-blockheads have to stick together.
Thanks again,
Warren, in MNhttp://forums.y-blocksforever.com/uploads/images/163d586d-446f-4764-9534-3955.jpghttp://forums.y-blocksforever.com/uploads/images/b64a4257-7c3b-44d4-9cd3-f5a6.jpg
Posts: 4.6K, Visits: 38.5K
Back in the day Smile we used a torch to heat up the retainer ring red hot then dropped it over the end of the axle. It would drop straight on tight and level. Of course a press works too.
snowcone
Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)
Posts: 169, Visits: 5.9K
I have never pressed them on and was taught to heat them and then drop them on when they expanded.
I replaced mine just a couple of months ago
I would be concerned about pressed ones coming off.
Gary - 1958 Star Customline and 1940 Ford Deluxe Hotrod
2721955meteor
Posts: 927, Visits: 190.0K
Where is the retainer in the picture of the installed new bearing.
I put the axle in the freezer over night, then warm the bearing inner race (put the retainer on first) use the old ring to tape the new bearing in to place. then heat the new retainer to install.
On removing the old bearing, heat the retaining ring, or cut with a grinder. with the bearing wrap alight rag around the bearing put on your safety glases,block of wood under the bearing or steel and take a 5 pound hamer and back the outr portion. it will split then heat the iner race, or cut it with a grinder being careful not to nick the axel.  Only cut it 2/3 the way.then with a mild steal drift tapit off.
 No special pullers needed
Warren.  I’m guessing that the axle retaining plates are slotted so that they slip over the axle with the bearings already in place?  I’m like Cliff  in that I don’t see them on your axles with the freshly installed bearings.
82warren
Guys ... It takes plenty of pressure to push those bearings on, you cannot heat them.
The retainer ring is shown there, it's the smaller thing next to the bearing.  These bearings have no 'shoulder', that is the ring, up tight against the bearing.
Heating the rings is fine but no worries about using a good press, they go on tough, they aren't going anywhere.  They were pressed on in the Ford plants, not heated.  In fact, the rings and bearings could have been pushed on together in one quick operation, I'd bet the farm on it.
My cousin came out of WW2 in '46, worked for Ford as production engineer all his working life, he said everything was pressed together cold in specialized machines, things we guys can't duplicate in our shops, at least not real easy.
Hope this helps ...
warren
Warren.  I’m in total agreement on simply pressing the bearings and the retaining ring in place without the application of heat.  Only on some industrial applications did I have to use an induction heater to put a controlled amount of heat into the bearing to install the bearing on its hub.  But those were some monster large bearings also.
What Cliff and I were asking about are the axle retaining plates that fit between the bearing and the wheel flange and that plate keeps the axle from sliding out the housing when you go around a corner.  Ford called these the ‘outer rear wheel bearing retainers’.  I just don’t see this piece in your pictures.  These are held in place on the axle housing with the same four bolts that hold the brake shoe backing plates in place.  While most of these must go on the axle before installing the bearing, I have dealt with some that were simply slotted so that they would slip in place with the bearing already on the axle.  Here’s a picture of some different axle retaining plates.
http://forums.y-blocksforever.com/uploads/images/8423b71f-dba0-4b2f-a5d7-3892.jpg
2721955meteor
82warren (7/15/2016)
Hope this helps ...
warren
a bit of heat on the iner race and axel in the freezer works great,we are not all in front of a big press
carl
Posts: 1.2K, Visits: 20.6K
Warren if you are missing the retainer plates I probably have some stashed away that I will send you,just let me know  Carl
aussiebill
Posts: 1.8K, Visits: 11.4K
did you forget the retainer plate ?
 Down Under, Australia
