v belts
Posted By Ron Landphair 9 Years Ago
Ron Landphair
Problem Posted 9 Years Ago
Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)
Posts: 2, Visits: 15
I have a problem with the fan belts 0n my F-100 slipping.  Don't know if I have them  routed correctly.  I have added a double pulley at the crankshaft,   Power steering {brackets from John Mummwert
I have a belt slippage problem on my 55 F-100.  I am not sure how to route the belts.  I have added a crankshaft double pulley giving a total of three grooves. Power steering brackets (by John Mummert)  AC and alternator  bracket from Vintage air w/Double pulley.  G.M one wire alternator  w/double pulley.
Last Active: 2 Weeks Ago
Posts: 1.9K, Visits: 194.9K
Stock there were a couple different belt widths, depending on application. Mixing pulley widths would be a problem, especially with aftermarket pulleys. Old belts can get hard, or glazed. Many brackets require some shimming to get the alignment right. Any mismatch here could cause slipping.
I don't know about trucks, but generally the one belt is crank-gen-water pump. The p/s is crank-pump.
Ron Landphair
Thanks for the info.  All pulleys are the same width except the inner crankshaft pulley.  I didn't consider belt width.
