Sounds like an exhaust leak
Posted By Edsel Ed 9 Years Ago
Edsel Ed
Posts: 5, Visits: 16
Accelerating from a standing stop I get a sound like an exhaust leak. I changed the header pipe gasket 1st, no change. Cant see any cracks in the exhaust manifold and nothing loose down the exhaust system. I cant see inside the muffler but its quiet in the back? Any ideas where else to look of how to do a "shade tree" test? BTW the fuel pump is very noisy tap, tap, tap.
Last Active: 8 hours ago
Posts: 6.1K, Visits: 442.8K
Check valve adjustment.
The fuel pump shouldn't be noisy.  If you're sure it is the pump, maybe it needs a rebuild or replacement.
Edsel Ed
The sound is not like rattling valves at all. I am going to get someone to help me identify the location at an idle you cant tell there is anything wrong. Thanks
Edsel Ed
Hi Guys How about a crack in the intake manifold? It sounds like it coming from underneath the intake manifold under the Carb. Have not pulled it off yet, Ed
Edsel Ed
Can I get a range of good compression for a stock 292? Mine was just measured out at between 125 - 130 on all cylinders
At a reliable shop and I was also told its running strong with good vacuum (seems a little low) for a 120+k mile engine
Edsel Ed (6/30/2016)
At a reliable shop and I was also told its running strong with good vacuum (seems a little low) for a 120+k mile engine.
Lots of variables for cranking compression readings with the compression gauge itself being at the top of the list.  But as a general rule, the readings for all the cylinders are expected to be within 10% of each other from the lowest to the highest.
chiggerfarmer
Supercharged (177 reputation)Supercharged (177 reputation)Supercharged (177 reputation)Supercharged (177 reputation)Supercharged (177 reputation)Supercharged (177 reputation)Supercharged (177 reputation)Supercharged (177 reputation)Supercharged (177 reputation)
Posts: 85, Visits: 3.8K
I have had two 54 cars with 239 motors and the little 2V carbs burn holes in the exhaust part of the intakes, one on top and the other underneath. I have never seen any other year manifolds do this, but they very well may.
Tom from the chiggerfarm located in the beautiful Heart of Central Texas
When you cannot dazzle others with your brilliance, baffle them with bullcorn! BigGrin
