Last Active: 9 Months Ago
Visits: 183.3K
Should be OK now. That bell shaped P/U was wrong for that pan. Never seen one like it...what did it come off of?
"FREE SAMPLE"
It came off of a Y-Block, with that oil pan. I have three other truck pans and pickups which are off of engines and they are the type of pan without a baffle and have the removable screen type of pickup. One is an HD truck pan. Maybe the baffled pan came with the bell shaped pickup. When I used the non baffled pan, the pressure would drop considerably when coming to a stop. Maybe they revised the pickup position when they added the baffle, to prevent that.
Have you ever thought of making your own pickup? I looked at a lot of them and found a rectangular one where the line was on the side or at a slight angle up from one of the sides and not the top for my GMC 6. I found some 7/8" dia. steel tubing with some bends, cut, and welded until it was where I wanted. I believe it was a Moroso for a pretty large engine like a FE or Pontiac. As I remember the tubing on the pickup was a little smaller than the -12 bulkhead fitting I welded on and the sealed to the pan.. Good Luck.
Posts: 1.6K,
Visits: 5.2K
I think your on the right track with cavitation issue, are you restrickting flow to the top at all? The FE guys swear by running 1 quart over because they say the FE's will suck the pan dry on a hard run.
I've pinched the overflow tubes so that they have about a 1/32" opening.
Visits: 122.7K
The link goes to what is essentially an advertisement for Moroso Oil pumps. Is that what you meant to link?
Visits: 122.7K
Yes it does, I was thinking their description of cavitation and what they did was why I placed it.
Visits: 7.1K
I'm actually working with Moroso, to have one made. They'll have all of the engine specific info to build pans for Y-Blocks. Chassis clearance and such will be the responsibility of the buyer to provide.
