Freeze plug locations
Posted By V8-1 9 Years Ago
V8-1
Question Posted 9 Years Ago
Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)
Posts: 2, Visits: 7
I have a 1962 F-250 that needs freeze plugs (31 K original miles.) I can see 3 per side.. Any in the back, under the bell-housing?
In the block, there should only be two freeze plugs per side, not three.  There are no freeze plugs at the front or rear of the block.  Total of four 1¾” freeze plugs in the 239-312 Y blocks.
V8-1
Posts: 2, Visits: 7
Ted:
Thanks for the "freeze plug" answer... it sure looks like there are three per side.
How difficult to get these out?
I have enough room under the truck to pry them out if I use "jack stands."
I have not done freeze plugs before.
V*-1
