running issue
Posted By zrd32 9 Years Ago
zrd32
Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)Hitting on all eight cylinders (6 reputation)
Posts: 2, Visits: 13
I have a 312  4 cylinders are running good but the other 4 cylinders have a carbon build-up on spark plugs. Where do i began to start?
Thanks-Zach
Posts: 6.1K, Visits: 441.8K
Which 4 have the carbon buildup?
zrd32
6,8,1.3
Those are pretty random. A tune up and compression check is probably a good place to start.
The only hint of a pattern I see is 8, 6, and 3 fire sequentially, but 1 is an outlier.  The 3 in sequence, maybe some sort of ignition issue.
